NKG or Bosch Oxygen Sensor? Any difference?
Old Jul 6, 2004 | 04:12 AM
James's Avatar
Default NKG or Bosch Oxygen Sensor? Any difference?
I am replacing oxygen sensor on my accord with 180k - yes, the original OS..i wonder if Bosch OS would be fine or should I stick to NKG OS? NKG OS costs twice than the bosch one. Any difference between these two brands?
Thanks in advance.
Jim
Old Jul 6, 2004 | 09:46 AM
boostin4drcivic's Avatar
Default Re: NKG or Bosch Oxygen Sensor? Any difference? (James)
price is your main difference. i have had experience with 2 bosch universals, and they did the job for me. i used one on my turbo civic with a seized o2 sensor and one on my buddys 2nd gen teg with a seized o2 sensor when putting on header. the bosch comes in 2 types, the universal which u have to cut the harness plug and do a little wiring for $65 or so. then theres the bosch OEM replacement direct plug in which is about $120.
Old Jul 22, 2004 | 02:26 AM
chadc's Avatar
Default Re: NKG or Bosch Oxygen Sensor? Any difference? (boostin4drcivic)
I swapped my stock O2 sensor in my 98 Accord EX with VTEC 4 cyl for the Bosch universal and followed the wiring to the tee, but my check engine light has not gone off. Any ideas?
Old Jul 22, 2004 | 03:05 AM
Mike813's Avatar
Default Re: NKG or Bosch Oxygen Sensor? Any difference? (chadc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadc &raquo;</TD></TR><TR><TD CLASS="quote">I swapped my stock O2 sensor in my 98 Accord EX with VTEC 4 cyl for the Bosch universal and followed the wiring to the tee, but my check engine light has not gone off. Any ideas?</TD></TR></TABLE>
you sure the check engine light was for the o2 sensor? grab the code and double check to see whats wrong.
Old Jul 22, 2004 | 03:41 AM
chadc's Avatar
Default Re: NKG or Bosch Oxygen Sensor? Any difference? (Mike813)
I had the code checked b at the autozone near my house and we checked in their computer and it was for the bank 1 (exhaust manifold) O2 sensor. So that is why I am stumped I am think that may the wire didn't get a good enough connection to each other. Do you know what Class O2 Sensor the the stocker is?
Old Jul 23, 2004 | 08:39 AM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadc &raquo;</TD></TR><TR><TD CLASS="quote">I had the code checked b at the autozone near my house and we checked in their computer and it was for the bank 1 (exhaust manifold) O2 sensor. So that is why I am stumped I am think that may the wire didn't get a good enough connection to each other. Do you know what Class O2 Sensor the the stocker is?</TD></TR></TABLE>
try erasing the code, and see if it comes back on again?
Old Jul 25, 2004 | 08:34 PM
chadc's Avatar
How do you erase the code?
Thx,
Chad
Old Jul 26, 2004 | 04:53 AM
jweller's Avatar
pull fuse #13 in the passenger side fusebox for 10 seconds or more. the fuse is lableled clock/backup. it is NOT the one that says ecu
TOO MUCH TORQUE
Oct 18, 2013 06:09 AM
hondatuningboi96
Dec 6, 2006 02:48 AM
93supercoupe
Aug 27, 2006 11:52 AM
coolrahool
Mar 25, 2005 11:06 PM
Superman137
Jan 14, 2005 02:24 PM
