Viper ESP600, just bought car, no remote
I just bought a car and the seller couldn't find the remote for the alarm. The car at the moment doesn't use the alarm, I just lock it manually and everything is cool. I was wondering what would happen if I disconnected the battery and put it back?? It would suck if I would not be able to start the car after I put back the battery... I need to do a swap in the next week and I don't know what I should do. I don't really want to get an alarm but I might just have to.
btw this is a 92 Nissan 240sx. Thanks guys
Or is there a way to disable it without the remote?? I have no clue on how to remove the whole thing if that's a better thing to do.. And I don't want to pay someone to do it, might as well pay a lil more and get an alarm/keyless entry
Just get a new remote, program it into the alarm, and program out the all other remotes, right now someone else has access to your car
hope this helps. 94
hope this helps. 94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Just get a new remote, program it into the alarm, and program out the all other remotes, right now someone else has access to your car
hope this helps. 94</TD></TR></TABLE>
Exactly what i was thinking. If i bought my ITR with an alarm in it and no remote, i would be shitting my pants. And since, its a 240...turbo??....i'd swap brains ASAP. Just call DEI up and send back the brain, tell them its defective, and they'll send you a new one. Go buy a new remote, and program it, and you are done.
just go to an authorized viper dealer, or any directed security dealer for that matter..they can get you a new remote that you can program after your swap....ask them to print you a copy of the install manual...or get it yourself at dei.com....should cost you like 40 bucks max for the remote.
Ok where can I buy a remote and get it programmed?
Also I recall calling Circuit City a while back... they had universal remotes that could be programmed, but the guy said that there's a possiblity that it wouldn't work or something, and once I open the box I can't return it. Something like that, this was a few years ago before I got this car.
So where should I go to get the remote, and also what kind of remote do I get?
directed.com
look up the nearest retailer near you. they can order(some might have it in stock) a new remote and program it for you. if your that worried about the alarm, just unplug it. unplug the brain from the harness. dei used a open when armed starter kill. if the alarm is unplugged you will still be able start it.
OK guys I just looked at it. It's not a Viper 600 like I was told. It's a "Clifford Novell" and has "8161" not sure if that's the model # or whatever.
So I can just unplug the brain and my car will still start? How certain are you... because I don't want to unplug it and then my car won't start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civichb »</TD></TR><TR><TD CLASS="quote">OK guys I just looked at it. It's not a Viper 600 like I was told. It's a "Clifford Novell" and has "8161" not sure if that's the model # or whatever.
You can get a new remote for the Clifford "Novell" [also from DEI]
Yes just unplug it, then try and start the car,if car does not start you have a normaly open starter cut relay,you will have to plug the alarm back in,or bypass the starter cut relay.
hope this helps.
94
</TD></TR></TABLE>You can get a new remote for the Clifford "Novell" [also from DEI]
hope this helps.
94
hope this helps.
Ok, just wanna make sure that if I do this, the alarm would not go off if I plug back the brain... similar to when you unplug the battery, and plug it back. Wanna make sure before I do this.. thanks for the help so far guys
hope this helps.
94</TD></TR></TABLE>Ok, just wanna make sure that if I do this, the alarm would not go off if I plug back the brain... similar to when you unplug the battery, and plug it back. Wanna make sure before I do this.. thanks for the help so far guys
Ok, just wanna make sure that if I do this, the alarm would not go off if I plug back the brain... similar to when you unplug the battery, and plug it back. Wanna make sure before I do this.. thanks for the help so far guys</TD></TR></TABLE>
Just turn on ign. before you plug in the alarm[ silent power up ].
94
94
pdd
Honda Civic (2001 - 2005)
Jul 28, 2007 09:50 AM
