car shakes
Old Jul 5, 2004 | 08:25 PM
racuss6's Avatar
Default car shakes
this is the problem that i have. i have a 97 dx w/a b series. everytime i accellerate the car shakes. it only happens rite when i get it in gear and get on the gas. it doesn't do it when im cruising. it also happens when im in 5th going bout 80 n i get on the gas. i think it might be the mount bushings cause they're pretty worn. ne one got ne ideas?
Old Jul 5, 2004 | 08:35 PM
racuss6's Avatar
Default Re: car shakes (racuss6)
help me
Old Jul 5, 2004 | 08:39 PM
crashN2u's Avatar
Check to see if your lug nuts are nice and tight. I had a similar problem that got progressively worse to where I couldn't go more than 45 mph without the car violently shaking. I had lost a lug nut and two of the other ones were loose.
Old Jul 5, 2004 | 08:41 PM
racuss6's Avatar
Default Re: car shakes (crashN2u)
yeah i thought that was the problem at first but its not. i check them n they're still torque down to specs.(80 ft. pounds)
Old Jul 5, 2004 | 08:56 PM
1fst4's Avatar
Id go with the mounts
I had my b16 in my hatch before my h22 went in and when i would get on it,it would shake and vibrate like the motor was gonna drop out
When i pulled it out to swap motors i noticed that my rear mount was shot and my driverside was ripped when the nut was taken off just kindda fell apart
Old Jul 5, 2004 | 08:58 PM
mrcch's Avatar
Also check to make sure your axles are installed properly and there are no problems with them.
I busted an axle one time and it still worked but would vibrate when I accelerated. Just my $.02
1320king
43
Jan 17, 2008 05:10 PM
i_VTEC
Oct 3, 2007 05:07 PM
sExy_TinKY
Dec 26, 2005 11:11 PM
FOrSfEd
Feb 8, 2005 08:22 AM
swtcivic93
Jul 15, 2002 07:53 PM
