Srange sound in gear box or tranny..
Old Jul 5, 2004 | 08:08 PM
CRX_RUS's Avatar
Default Srange sound in gear box or tranny..
This sound is audible constantly, except for the moment when I squeeze out clutch pedal. What can it be? It can the bearing? THEN what?
Old Jul 5, 2004 | 08:23 PM
0554's Avatar
sounds like the throw out bearing maybe.
Old Jul 5, 2004 | 08:30 PM
michael O's Avatar
Default Re: (88crex)
can you describe the sound?
Old Jul 5, 2004 | 08:54 PM
CRX_RUS's Avatar
Default Re: (michaelOlson)
Resounding knock.. Tock-tock-tock.. At dump of RPM's becomes more distinct..
Old Jul 5, 2004 | 09:06 PM
fourthgenhatchB17's Avatar
Default Re: (CRX_RUS)
Could be the input shaft bearing (not the same as throw out bearing) but its hard to tell with ur description. The sound should be noticable at idle, then when u push the clutch in, it should go away.
Old Jul 5, 2004 | 09:14 PM
CRX_RUS's Avatar
Yes, then I push the clutch in, it going away.
Old Jul 5, 2004 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_RUS &raquo;</TD></TR><TR><TD CLASS="quote">Yes, then I push the clutch in, it going away.
Ok. Some say the noise also sounds like a helicopter. What u are goin to need to do is drop the tranny, split the case open, replace the input shaft bearing AND seal, reseal the case, put back in car. If u let it go long enough, the seal will eventually give out and u will leak oil like crazy and ur clutch will start to slip (due to oil on the disc). You should see some of the input shaft bearings that i have replaced...they came out in pieces.
Old Jul 5, 2004 | 09:59 PM
CRX_RUS's Avatar
Can u show me the pics of this bearing? I've a D16Z6 engine with manual tranny..
Old Jul 5, 2004 | 11:40 PM
Your best bet is to search on hondaautomotiveparts.com or something similar to try and find it.
jimbrown
Jul 17, 2007 12:35 PM
slammin86
11
Nov 14, 2005 04:21 AM
B00STED Si
Aug 30, 2005 04:00 PM
uNF$@#!
May 13, 2005 07:59 AM
sLoWrAcEr
Dec 14, 2004 09:17 AM
