Removing side markers to install new ones
if i remmeber correctly you pull back towards the rear of the car while lifting the side marker off the car.
if that doesn't work then pull towards the front of the car
you will see a slot where you can stick your key (along the trim of the marker light)
just stick your key or a thin flat head screw driver and push then pull out.. (there is a tab inside the holds it to the body)
replace the socket and bulb onto the JDM OE clear ones and snap them back on to the car...
for added security I placed some 3m adhesive to the back side before placing them on.. they can still be pulled of, but not so damn easy...
Here you can find complete install instructions with photos...
Right Click / Save As
http://www.prestigeautoaccesso...l.pdf
No tools needed.
No tools needed.
CBXweb
Jan 22, 2004 07:53 AM
mickey513
Audio / Security / Video
Jul 10, 2002 11:22 AM
