I need help ASAP!!
Old Jul 5, 2004 | 03:41 PM
d16z6crx's Avatar
Default I need help ASAP!!
Ok heres the problem. Im almost done with my d16z6 swap. I stayed obd0. I have a DX CRX but I converted to MPFI. The engine harness will not plug into the firewall harness. does anyone know why? Do I need the HF/SI in car harness as well?
Old Jul 5, 2004 | 04:30 PM
Redline130's Avatar
Default Re: I need help ASAP!! (d16z6crx)
How did you convert it to MPFI? The Si or HF harness won't do you any good other than being a donor for some connectors. You should use your DX harness and add the necessary wiring to the harness. (If you didn't do it that way).
Old Jul 5, 2004 | 07:06 PM
blah13's Avatar
Default Re: I need help ASAP!! (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">How did you convert it to MPFI? The Si or HF harness won't do you any good other than being a donor for some connectors. You should use your DX harness and add the necessary wiring to the harness. (If you didn't do it that way).</TD></TR></TABLE>
Yup, you have to use the stock harness, not the one that came with the motor. At least its 100x simpler this way.
Old Jul 5, 2004 | 09:25 PM
JapJunkie's Avatar
Default Re: I need help ASAP!! (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, you have to use the stock harness, not the one that came with the motor. At least its 100x simpler this way.</TD></TR></TABLE>
Werd
crx89backedout
Jan 14, 2010 03:36 AM
shackler
Mar 22, 2007 07:21 PM
dwchkypmp20
11
Dec 10, 2003 03:57 PM
DOHC_EF
Oct 12, 2003 05:56 PM
HybriDNA
Feb 10, 2003 08:50 AM
