Integra wire harness
Old Jul 5, 2004 | 02:34 PM
85mm LS VTEC's Avatar
Default Integra wire harness
Will an 90-93 0bd0 Integra wire harness work in my EF with an Ls/VTEC swap?
Modified by 85mm LS VTEC at 10:28 AM 7/6/2004
Old Jul 6, 2004 | 09:29 AM
Default Re: Integra wire harness (85mm LS VTEC)
Quick answer EF guys will be fine.
Old Jul 6, 2004 | 09:54 AM
Jester88Si's Avatar
only the 90-91 DA's obd-0 92-93 is obd-1. I'm sure it wont work because the pin-outs are different
Old Jul 6, 2004 | 10:20 AM
4drEF's Avatar
Keyboard Humorist
Just the engine harness?
What trim is your car originally?
Anyway, you want to use the engine harness that came with your car.
You don't use the harness from the engine and try to make it work in your car.
Generally you will fail miserably. It's way more work than what you do to convert the stock harness.
swappedefloveit
Jun 9, 2013 04:49 PM
seldon
Jul 3, 2009 09:22 PM
turboteg90
Jun 4, 2008 02:06 PM
D3U1LT
Sep 15, 2006 08:33 PM
