AC issues
Old Jul 5, 2004 | 02:02 PM
nixadm's Avatar
Default AC issues
Hey guys, who can point me in the right direction.. I have a 96 civic with ac blowing hot. I think the high pressure system has/had a leak.. I am really on a budget, any suggestions on troublingshooting this myself?
Thanks
Old Jul 5, 2004 | 02:14 PM
Turbo E's Avatar
recharge the system.
but thats uselss if you STILL have a leak. fix it properly. pressure test, then refill.
Old Jul 5, 2004 | 04:22 PM
nixadm's Avatar
Default Re: (Turbo E 604)
the presure on the low presure system is fine..I've already tested that, it looks like the high presure hose might have sprung a leak when I got in a wreck in the past, anyone know how to test that?
Thanks
Old Jul 5, 2004 | 06:44 PM
MAD B16's Avatar
Default Re: (nixadm)
At work we always recover any refridgerant in the system then pressurize the system to 300-400psi with nitrogen then if you dont hear and o-rings blow out spray down al your componets (lines, compressor, condensor,ect.) if the system is holding pressure then you are fine. it sounds to me as though your compressor has either took a crap on you or your expansion valve or orfice tubr is got trash in it from where the compressor has come apart. I have seen it before where the compressor clutch and everything comes on as always but it is not working properly. maybe my 2 cents worth helps.
Old Jul 5, 2004 | 07:32 PM
BatuKing's Avatar
Default Re: (shatteredream69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shatteredream69 &raquo;</TD></TR><TR><TD CLASS="quote">orfice tubr is got trash in it </TD></TR></TABLE>
sorry Honda only use TXV's
The only thing that can help us diagnose this problem is for you to tell us what your pressure readings are.. Now give me one at idle and one with your car running at 2000 RPM.
Old Jul 5, 2004 | 08:59 PM
murtnabila's Avatar
Default Re: (BatuKing)
I've heard you can get some dye to add into you a/c system and check and see under a black light to see if there in any leaks.
Zebra
Honda Civic (2006 - 2015)
10
Jul 5, 2018 04:32 PM
Bad_dude
Dec 3, 2010 09:49 PM
M@
Mar 31, 2007 10:14 AM
dawnriver
Nov 5, 2006 05:35 AM
Trey
Jul 14, 2003 08:58 AM
