98 EX + GSR ECU
thats what I mean, why would he swap a sohc ecu running a sohc. And get a dohc ecu running a sohc motor. Especcialy if that car has vtec, that seems like that would make it work. I guess the genius thinks that because it's gsr it must be really fast. what an idiot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">i had a friend put a 00 Si ecu in his 00 ex, he said it he felt a noticable gain.</TD></TR></TABLE>
Right, the programmed fuel injection is different from the EX and Si ECU's from DOHC to SOHC, RPM and vtec are set differently when activated. Si ECU will not be able to read correctly on an EX so I think your friend is just BS'in.
