Fuel pump replacement
Has anyone replaced thier fuel pump. I have a Holley intank to go in my 89 hatch. The pump is actually for a 92-95 civic will this pump work in my car.Please if anybody knows I would really appreciate your advice.
It will work but you will need to cut the plug off the harness and put new ones on that match the holley, I think you can use speaker spade terminals. Think thats what I used on mine. It's a bitch though cause you have to drop the tank. Make sure when you mount up the new pump that it sits in the exact same position as the stock one did. Make sur the strainer is in the same place.
