EGR insufficient flow? P0401 code
Old Jul 4, 2004 | 06:54 PM
97minitaco's Avatar
Default EGR insufficient flow? P0401 code
My wife just got a 98 2dr Accord V6 with 90,000 miles on it. The CE light has been on since we got it. Today I put a code reader on it and found this code.
P0401: Egr insufficient flow
Is there a way to fix this and what exactly would the problem be? The car runs fine, but the CE light keeps coming back even after I clear the codes. The car sat for over a year without running because it was wrecked. My father in law just completely reworked the car for my wife. Everything is great on it except for that one code.
Old Jul 4, 2004 | 09:21 PM
Chiovnidca's Avatar
Default Re: EGR insufficient flow? P0401 code (97minitaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97minitaco &raquo;</TD></TR><TR><TD CLASS="quote">
Is there a way to fix this and what exactly would the problem be? </TD></TR></TABLE>
Common problem, the EGR port is clogged up. Pull off the intake manifold and clean it out.
Old Jul 5, 2004 | 06:08 PM
hondadude's Avatar
The latest service bulletin calls for the port at the plenium to be opened up a little bit to make the flow better. There was also a recall that rerouted the pcv plumbing.
You can ask a honda dealer to run a VIN status inquiry to be sure that has been updated.
Old Jul 5, 2004 | 06:34 PM
Chiovnidca's Avatar
Default Re: EGR insufficient flow? P0401 code (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">The latest service bulletin calls for the port at the plenium to be opened up a little bit to make the flow better. There was also a recall that rerouted the pcv plumbing.
You can ask a honda dealer to run a VIN status inquiry to be sure that has been updated.</TD></TR></TABLE>
8 years or 80,000 miles. He's a little too late.
bcintron95
Aug 26, 2013 06:08 PM
realmike15
Honda Civic (2001 - 2005)
Apr 17, 2011 06:07 PM
lax1089
Mar 28, 2007 10:03 PM
flyguy
Jul 26, 2005 06:28 AM
Knightmare69
Sep 27, 2003 09:41 AM
