USDM type r pistons w/ eagle b16 rods in stock b16 block????
I am picking up a set of USDM type r pistons, and some eagle b16 rods. I have a b16 block, will this set up work? what parts do i need to get to work? someboday said i will need itr wrist pins... thanks for ur time (i have tried searching but found nothing that helps)
stock rods are fine for that setup, if you want to use the eagles you have to get pistons modified for a floating wrist pin setup which means they gotta notch a little ring where the wrist pins go to install the c-clip thingy
allspooledup
Mar 15, 2007 08:48 AM
allspooledup
Mar 15, 2007 08:47 AM
I wanna be Steve!
Jun 2, 2003 07:21 PM
