sputtering at idle after plug install
Old Jul 3, 2004 | 07:15 PM
ih8danoles's Avatar
Default sputtering at idle after plug install
Well after finishing up the greddy turbo install I decided to switch to a one step colder plug. I gapped the plugs to .030 and tightened them hand tight, and then 1/4 of a turn, which is what I read on this site. When the car is idling, it sputters a little bit, and sometimes enough to vibrate the car. Is there anything else I should do (reset the ECU, etc...)? Thanks for any input.
Old Jul 3, 2004 | 08:46 PM
nwdave's Avatar
Default Re: sputtering at idle after plug install (ih8danoles)
Did the car run fine after the turbo install? Or did you do both and now it runs rough?
Old Jul 3, 2004 | 08:47 PM
delScho's Avatar
Definitely reset the ecu. And are you sure you got the plugs in the right order? That's usually a big culprit when doing tune-up type stuff.
Old Jul 3, 2004 | 11:35 PM
crashN2u's Avatar
Default Re: sputtering at idle after plug install (delScho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delScho &raquo;</TD></TR><TR><TD CLASS="quote">Definitely reset the ecu. And are you sure you got the plugs in the right order? That's usually a big culprit when doing tune-up type stuff.</TD></TR></TABLE>
There's an order to installing spark plugs? I'm not being an ***, I just never heard of it. If so does it only apply to colder plugs?
Old Jul 4, 2004 | 07:00 AM
delScho's Avatar
Default Re: sputtering at idle after plug install (crashN2u)
Sorry, wires. Not plugs. My bad.
Old Jul 4, 2004 | 09:58 PM
ih8danoles's Avatar
Default Re: sputtering at idle after plug install (nw.dave)
The car ran fine from the turbo install until now. I will say, that the first time I drove the car, I had the MAF wire backwards on the blue box wiring, and the car feels like it did then. Sorta sluggish at first until it hits WOT. I will definitely reset the ECU tomorrow. Any other suggestions?
Old Jul 5, 2004 | 07:01 AM
ih8danoles's Avatar
bump for late reply last night.
bujeezus
Nov 10, 2010 10:58 AM
noood
Apr 20, 2008 07:46 AM
thestorysritehur
Mar 11, 2008 08:34 PM
Thanks knightsport!
Apr 9, 2005 02:50 PM
armharm
Oct 31, 2002 11:51 AM
