loss of fuel pressure
Old Jul 3, 2004 | 03:52 PM
hcarcrx's Avatar
Default loss of fuel pressure
ok heres what is done, b16a w/ h/i/e and msd, i can start the car and idle fine with about 35 psi of fuel pressure, go to drive and it acts like is out of gas, of loosing fuel pressure, ive replaced fuel pump, fuel pump relay and trouble shooting all the factory service manuel says to but it is still the same problem , please help loosing hair pulling it out!!
Old Jul 3, 2004 | 03:54 PM
DXDOHCVTEC's Avatar
Is it the factory b16 fuel rail and regulator? I would think if you replace the FPR it should tae care of the problem.
Old Jul 3, 2004 | 04:03 PM
hcarcrx's Avatar
Default Re: (DXDOHCVTEC)
im loosing the pressure at the fuel filter, also new too
Old Jul 3, 2004 | 05:54 PM
JDMotive's Avatar
Default Re: loss of fuel pressure (hcarcrx)
Did it run right before you installed the MSD?Ive had problems like that in the past when installing MSD's.You really dont need it at all.Ive run the stock ignition with over 200whp NA and 300whp turbo.
jman86
Nov 7, 2024 12:19 PM
yywjsutherla
Honda CR-V & Element
Sep 13, 2017 12:38 PM
91tealhatch
Nov 3, 2008 07:10 AM
ricecooker415
Aug 14, 2005 08:00 AM
