zex nitrous kit help
Old Jul 3, 2004 | 02:55 PM
trevorclaus's Avatar
Default zex nitrous kit help
if anybody is familiar with how to program the nmu, it just stays in learn mode, it seems like its not getting any info from the tps, all the wiring is good, been checked and rechecked, the white wire out of the nmu is hooked up to the red/blue wire on the tps
has anybody had this problem before?
thanks
Old Jul 3, 2004 | 03:07 PM
Default Re: zex nitrous kit help (trevorclaus)
ok, i run through the programming mode, do everything the instructions say, but i can't get the light to turn steady green saying it is properly programmed, it just stays solid red after turning the system off and on again. IT is flashing during the program mode from red to green to off, but thats all i get after the programming before i shut the system off
Old Jul 3, 2004 | 07:01 PM
Curtis2kul's Avatar
what i did was push the little black button on the side until it started blinking colors. then went inside and held the pedal down WOT for like 30 sec. Then let off. then it was solid green Just call the zex helpline! Real friendly
Old Jul 4, 2004 | 05:05 AM
Default Re: zex nitrous kit help (Curtis2kul)
thanks a lot man, i think something is wrong with the button cause when i push it, doesn't do anything,
hondateg10
Oct 11, 2008 10:03 AM
Soccerking3000
Jun 7, 2004 02:22 PM
shoebox
May 28, 2003 07:07 PM
stockludesi
Apr 20, 2003 01:32 AM
S13 slide
Sep 6, 2002 08:34 AM
