HID retrofit relay question
Old Jul 3, 2004 | 01:10 PM
bolohuu's Avatar
Default HID retrofit relay question
I was looking over this article on retrofitting HID to a ITR:
http://www.skafia.com/itr/hid/
I noticed in step 7 that a relay wasn't used to connect the stock headlight wiring to the ballast. All that was done was the headlight fuse was changed from 10a to 20a. I keep reading that a relay should be used in between the stock headlight harness and the HID ballast in order to stop your stock wiring from getting damaged. What are your opinions? Can I get away without using a relay when installing HID on my 99 Integra like the guy in the article did? Thanks in advance.
Old Jul 3, 2004 | 08:46 PM
fcm's Avatar
fcm
Old Fart
Default Re: HID retrofit relay question (bolohuu)
Go with the relay, can't be to safe. 94
Wrona
Sep 18, 2011 07:27 AM
nathanjohnson2009
Apr 3, 2009 04:11 PM
bolohuu
Jul 10, 2004 02:00 PM
bolohuu
Jul 5, 2004 09:25 AM
LshatchTurbo
Aug 20, 2002 10:24 PM
