Simple question on a 90 Accord.
Old Jul 3, 2004 | 04:33 AM
Kinnder's Avatar
Default Simple question on a 90 Accord.
1990 Accord LX....How do I change the headlight(s)? Sorry if this has already been addressed, but I searched and found nothing. Thanks.
Old Jul 3, 2004 | 05:41 AM
StimpyBoy's Avatar
Default Re: Simple question on a 90 Accord. (Kinnder)
You have to remove the front bumper to get at all the bolts holding in the headlights. Here's what I remember on my 92...
- Unscrew, unplug front turn indicator lights, remove from bumper. There are 2 bolts behind each light holding bumper on.
- Unscrew both screws in each front wheel well for bumper.
- Remove nuts in engine bay holding bumper on. One is down near the cruise control module, and the other one is near the battery tray. I had to remove both the battery and cruise control module to get to them
- Profit!
Old Jul 3, 2004 | 06:03 AM
Kinnder's Avatar
Default Re: Simple question on a 90 Accord. (StimpyBoy)
Sorry....what I meant was how do I change the headlight bulb. Thanks
Old Jul 3, 2004 | 12:44 PM
f22b-dohc's Avatar
lol
Old Jul 3, 2004 | 12:55 PM
.bagged's Avatar
Default Re: Simple question on a 90 Accord. (f22b-dohc)
rotate the black thingy clockwise and then pull the bulb straight out. be sure not to touch the bulb with your fingers. do in reverse to replace
Old Jul 3, 2004 | 01:50 PM
Riceburner247's Avatar
Default Re: Simple question on a 90 Accord. (bagged93accord)
Well, if the bulb you're taking out is already bad, then it doesn't matter if you touch it. Just don't touch the new bulb you're putting in. The oils from your fingers can get on the bulb. When the bulb heats up to normal temp, the oil can cause the bulb to explode.
The black collar around the headlight bulbs should turn allowing the bulb to be removed. Installation is reverse. Remember, don't touch the new bulb.
Old Jul 4, 2004 | 06:02 AM
Kinnder's Avatar
Default Re: Simple question on a 90 Accord. (riceburner247)
Thanks, but on the passenger side bulb (low beam) will I need to remove the battery, because the way it looks it seems I will need to....? If so how easy is that?
Backk InTheDA
Oct 4, 2010 05:14 PM
SI-lent
Mar 22, 2006 04:02 PM
eauto
Jan 25, 2006 12:43 AM
BlaqK20
Oct 8, 2004 05:12 PM
azian21485
May 11, 2004 08:13 AM
