Fuel Consumption after replacing OEM intake with Aftermarket Intake
Old Jul 3, 2004 | 12:38 AM
iampeetor's Avatar
Default Fuel Consumption after replacing OEM intake with Aftermarket Intake
I would like to ask if there is anything that i can do to lessen the fuel consumption on my 01 Honda Civic Ex MT. After i installed the Aftermarket intake my fuel usage almost doubled. Even when i don't High Rev. Is there anything i can replace to lessen the fuel consumption while maintaining my current HP?
Old Jul 3, 2004 | 12:55 AM
Full Race A6's Avatar
Default Re: Fuel Consumption after replacing OEM intake with Aftermarket Intake (iampeetor)
Your motor is using double the fuel it used to be using? Do you know how many miles you are getting per gallon?
You must have done something wrong man and your car is fine and your just thinking wrong
OR
Youre car is running insanely rich and just pumping to much fuel into your engine, definetely something Id bring my car to a mechanic to figure out but Im sure someoen on here will be able to help ya
GL
Old Jul 3, 2004 | 01:52 AM
hatchback_al's Avatar
Default Re: Fuel Consumption after replacing OEM intake with Aftermarket Intake (W O T)
Most cars get better gas mileage after installing an intake....
Old Jul 3, 2004 | 07:37 AM
busychild's Avatar
try resetting your ECU. It is unlikely that your ECU is not compensating for the amount of air intake, but it is worth a try before consulting a mechanic.(unless he's a friend )
Lee-joe
Jul 19, 2015 12:40 AM
Coreypickett
Apr 25, 2015 08:24 PM
DelSolMarine
Oct 14, 2011 03:46 AM
top fuel
Jun 13, 2004 02:19 PM
