Mis-fireing?
I don't know exactly what the problem is with my car, its a 1989 Civic HB SI, when I speed up it seems to miss fire, but it only happens when I get to a certin RPM, mainly around 3K, but after a bit it will get lower and lower when it miss fires or whatever is wrong with it, any help with this would be greatly helpfull!
I bought the car. . . .about 4-6 months ago. The guy said he kept up on all the maintenance things, but he did seem kinda half baked if ya know what I mean, so I don't believe he touched the engine at all, i'm about 200 miles away from having 189,000 Miles on the stock motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic_si »</TD></TR><TR><TD CLASS="quote">he did seem kinda half baked if ya know what I mean </TD></TR></TABLE>
Oh I know what you mean.
Well being that you dont know for sure what he did you should check out a bunch of things with that many miles. As far as the problem goes take off the distrubuter cap and look at the points inside also when the cap is off look at the rotor they normally get replaced at the same time in a normall tune up.. If they dont look NEW you should replace those along with plugs/wires. Other then that if you havent got anything done as for maintainance take a look at coolant/trans fluid.
ok, got new cap and rotor that i'm putting on today, my only problem now is that I keep on breaking the screws that go in to secure the cap, so i'm getting pissed off at that >.< When I get it in finally i'll let ya'll know if thats what was wrong
ok, got the new cap and rotor on, but its still doing the same thing, its almost like it jumps a beat when it hits 3k RPM, I don't know what to do about it any more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkid88Sir »</TD></TR><TR><TD CLASS="quote">maybe u got a exhuast leak?</TD></TR></TABLE>
What would the exhaust leak do to the car?
