b16a Overheating> Rapid temp gauge increase. Need help QUick.
Old Jul 2, 2004 | 08:46 PM
markpa2's Avatar
Default b16a Overheating> Rapid temp gauge increase. Need help QUick.
I was driving pretty hard today, and notice that my temp gauge started to go up real fast i d say prob 30 seconds at most and it got to the top, so i turned the car off, waited like a minute and turned it back on and the gauge was where it suppose to be. Later that night after driving hard again same thing happened,
So it only goes up when i beat on the car and it instantly goes down when i turn the car off and on., any suggestions?
Ive got a 91 civic b16.
Old Jul 2, 2004 | 09:34 PM
markpa2's Avatar
Default Re: b16a Overheating> Rapid temp gauge increase. Need help QUick. (markpa2)
I did several searches, all ic ame up with is
it could be my sending unit,badd ground, fuse?
Its not my thermostat cause the upper hose was hot. My water pump was also replaced,.....
????Could\\\\\
Old Jul 2, 2004 | 10:41 PM
Nerologic's Avatar
maybe it could be the waterpump telling you its going out, or maybe something along the lines of your coolent system is a weak link. I had this problem on my old b16 hatch, all i had to do when it started to overheat was turn on the heater for a bit and it would lower the gauge back to normal.....
Old Jul 2, 2004 | 11:06 PM
DXDOHCVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpa2 &raquo;</TD></TR><TR><TD CLASS="quote">Its not my thermostat cause the upper hose was hot. My water pump was also replaced,.....</TD></TR></TABLE>
Well if it isnt those ^ and the radator is not clogged up (somehow) then it would probably be the temp. sending unit. Espacially cause if you turn it off and back on and all the sudden its running temp again. When the gauge says its hot does the engine seem like its really hot?
Old Jul 2, 2004 | 11:51 PM
DC 2's Avatar
my friends car had the same prob, it occured after changing a heater core hose. We think its an air pocket in the system. There is a bleeder valve next to the top radiator inlet on your cyl head. try bleeding it....
other over heating probs can be thermostat, fubared radiator, coolant fan, lack of coolant.
Old Jul 3, 2004 | 07:02 AM
markpa2's Avatar
Default Re: b16a Overheating> Rapid temp gauge increase. Need help QUick. (DXDOHCVTEC)
The engine was really hot, the fan didnt go on though when it was that hot and stting in idle....should it have gone on? ANyways im gunna check to see if the fan works, and see if any thing is disconnected.
Im pretty sure it s not the water pump i new oem one was put in 2 weeks ago.
Old Jul 3, 2004 | 07:05 AM
markpa2's Avatar
Default Re: b16a Overheating> Rapid temp gauge increase. Need help QUick. (Nerologic)
we tried putting the heater on and it didint work, it just stayed up there, like i said the only thing that made it go down is turning the car off, I didnt have problems the rest of the night .............
Old Jul 3, 2004 | 07:12 AM
Keebler's Avatar
Head gasket.
Old Jul 3, 2004 | 08:16 AM
markpa2's Avatar
Default Re: b16a Overheating> Rapid temp gauge increase. Need help QUick. (Keebler)
headgasket? Lol
try unplugged fan.
Yeak i check today and it was my ******* fan it got unplugged ??anyways i plugged it back in and tapped it up.
Thanks for all the comments guys.
Old Jul 3, 2004 | 12:08 PM
Keebler's Avatar
lol?
Guess if you hadnt found your unplugged fan, id be right.
Apparently i overestimated your extensive diagnosis and research of your problem.... Next time ill suggest something more asinine like your fan plugs, or maybe even ask if you added water/coolant to your system...
cpingor
Honda Civic (2001 - 2005)
Jun 7, 2011 11:24 PM
dizzzane
Jul 18, 2007 12:40 PM
