K20 head swap
* B A N N E D *
im thinking about a K20 head swap for my 03 Accord Ex. will i be able to keep my stock ECU or will i have to get the ECU from an RSX or a civic si. or should i just upgrade to a hondata.
being that its a vtec head you might have too unless it has the wiring for it like the h23 does. but if you can afford the hondata i would go with that
goodluck with the frankenstein
yea......but let us not forget that with the wonderful k series, not only can you swap a Civic DX head for a CTR/IRT head, you can swap an Accord LX head for a CTR/ITR head......and heres the best: CRV head w/ CTR/ITR Head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">yea......but let us not forget that with the wonderful k series, not only can you swap a Civic DX head for a CTR/IRT head, you can swap an Accord LX head for a CTR/ITR head......and heres the best: CRV head w/ CTR/ITR Head
now were talking business with that setup
"k series...the new wave of the future"
</TD></TR></TABLE>now were talking business with that setup
Why don't you do a tsx head swap and tsx exhaust and intake manny along with the ecu?
Basically minus internals it would be a tsx engine
the rsx-s is a k20....tsx and accord are k24
Heres a link you might find useful, which I found by searching:
https://honda-tech.com/zerothread?id=888508
* B A N N E D *
a few reasons y i wouldnt swap the TSX head on my K24A4 block. its rare and expensive. it comes with a throttle by wire and an ECU thats not compatable with other K-series engines. to make the TSX head swap easier i would have to intall a K20A3, or A2 intake manifold & throttle body. i would also have to engineer a block off plate or plug for the EGR port on the TSX head. and the only advantage to a TSX engine is the high compression which makes alot of power compared to the lower compression on the K24A4. the head is really no different from the A4 head excpept for the E/M and I/M like u said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote">I thought the 03 accord had a k24 :shrugs:</TD></TR></TABLE>
you are correct sir
you are correct sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03K24A4EX »</TD></TR><TR><TD CLASS="quote">im not looking for a JDM head. i just want a RSX Type-S head. will i be able to keep my existing ECU for this swap.</TD></TR></TABLE>
RXS-S ≈ IT-R......i dont think ud be able to keep the ECU, but why would you want to??? "better" ecu would better be able to take advantage of the head. ITM and EXM from TSX would also make some big gains. remember, K series REALLY respond well to bolt ons
as i lay dying
Apr 21, 2004 05:48 PM
