cooling fan clicks??
Old Jul 2, 2004 | 05:24 AM
Vic Nyce's Avatar
Default cooling fan clicks??
a week after owning the car, stock 96 EX with 85k, the cooling fan makes a clicking noise as it stops. while it spins, its quiet..any ideas?
tried search. this was all i found. thanks
https://honda-tech.com/zerothread?id=69440
Old Jul 2, 2004 | 08:24 PM
hondadude's Avatar
Default Re: cooling fan clicks?? (Vic Nyce)
when the motor brushes wear down the 'pusher' spring will keep making contact on the armature.
I've also seen aftermarket fan motors that have too hard of a brush and you can hear the brush going over the armature plates.
The bottom line is, as long as the fan is running don't sweat it. They aren't worth rebuilding anyway.
Old Jul 2, 2004 | 08:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vic Nyce &raquo;</TD></TR><TR><TD CLASS="quote">a week after owning the car, stock 96 EX with 85k, the cooling fan makes a clicking noise as it stops. while it spins, its quiet..any ideas?
It could be hitting something?
Old Jul 2, 2004 | 10:27 PM
Schmitey's Avatar
I got a 96 EX as well.
Its the fan rubbing on the engine mount. See for yourself. Shut it off and spin the pass. side fan by hand, you'll hear it lightly scrape. Follow the top of the radiator and there's two little nubs that support the radiator. Jam some toothpicks in there or something to pull it back away from the mount. You only need a little bit of clearance.
Hope this helps. Nuisance I know but its not gonna hurt anything.
Old Jul 3, 2004 | 03:51 AM
Vic Nyce's Avatar
Default Re: cooling fan clicks?? (Schmitey)
thanks for the replies guys. im going to try your tip Schmitey because this is definitely a nuisance
Old Jul 6, 2004 | 05:08 AM
Vic Nyce's Avatar
Schmitey you hit the nail on the head! the toothpicks didnt work for me tho. i ziptied the radiator to the rad support in an attempt to hold it in a more forward position but it didnt work either. im just gonna shave off a couple of mm from the tip of the guilty fan blade..or should i do all to keep it balanced??
bs-crx
Feb 27, 2011 12:10 PM
jdmlude_dude
Honda Civic (2001 - 2005)
Oct 20, 2008 05:44 AM
Accordiac
Feb 9, 2008 02:10 PM
xkrntamax
Apr 17, 2006 06:38 AM
devilpuppy
Dec 4, 2004 07:47 AM
