BEST CAMBER KIT
Old Jul 2, 2004 | 02:29 AM
JFG Kevin's Avatar
Default BEST CAMBER KIT
what's the best camber kit you guys think is the best our there right now...Take into consideration on how much adjustment it can handle...the price...and the way it perform....i have ingalls...and they broke on me...not sure why...but i'm thinkin it's because i went up on the curb hard....that mite of broke it...i'm tryin to replace them now and just wonderin what's good out there that people has used....the ingalls i had was realli squeeky....i didn't like it at all...you had to oil them every mouth or so...for the bushin...
Old Jul 2, 2004 | 09:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: BEST CAMBER KIT (aznstyler119)
I think I might get the OmniPower upper control arms, exact same as Skunk2 but for around $170.
Actually I'm also considering the OmniPower rear upper camber links, and also some sort of toe link like the ones from SRR.
Old Jul 2, 2004 | 10:04 AM
3.504's Avatar
Default Re: BEST CAMBER KIT (PatrickGSR94)
i dont like the ingalls goofy little things, i'd go w/ the skunk2 lookin thing or the skunk2 itself, whole new upper control arm . wish they just made one for a DA........
Old Jul 2, 2004 | 10:29 AM
..::91TEG-G2::..'s Avatar
Default Re: BEST CAMBER KIT (3.504)
try SPC i think its called, made by intalls, supposed to be some good ****.. not sure if the design is different tho, but check them out
Old Jul 2, 2004 | 10:30 AM
joewhite's Avatar
yea i need to get a camber kit also.. Droped mine with the Neuspeed Springs. You guys think i should go with the Skunk2? having the older bodystyle Integra
Old Jul 2, 2004 | 11:02 AM
SiYouLater's Avatar
Default Re: BEST CAMBER KIT (joewhite)
Omni Power
Old Jul 2, 2004 | 11:08 AM
patmcd's Avatar
Default Re: BEST CAMBER KIT (99FBPSi)
I have the skunk2 one and it works just fine. But if I had to buy another one Id probably get a omnipower since its essentially the same thing and cheaper.
Old Jul 2, 2004 | 11:11 AM
cu3tip's Avatar
Default Re: BEST CAMBER KIT (patmcd)
I like the Skunk2, I've used them on my LS, and now I have them on my GSR....never had any problems with them to this day.. skunk2
Old Jul 2, 2004 | 01:17 PM
Lord Helmet's Avatar
SPC ownz ALL
especially the new type by SPC. it looks almost exactly like the skunk2 camber kit except you can get a percise adjustment by the way of a built in screw bolt. also it has the adjustment for the castor too. can't beat that cost= $150 from Super Autobacs(Stanton, Ca)
BTW that price is for a EG civic.
Old Jul 2, 2004 | 01:27 PM
Seedc2's Avatar
Default Re: BEST CAMBER KIT (sleeperciv)
^^^ SPC is good stuff
Old Jul 2, 2004 | 02:18 PM
fergy016's Avatar
i have ingalls all the way around.
Old Jul 2, 2004 | 02:56 PM
gsrboi80's Avatar
Default Re: (fergy016)
skunk2 front ingalls rear
Old Jul 2, 2004 | 03:11 PM
SoCar's Avatar
Default Re: (gsrboi80)
i got front ingalls kit and it sucks... always squeaking and knocking. shoulda just got the skunk2 to begin with
Old Jul 2, 2004 | 04:32 PM
joewhite's Avatar
thanks for the help looks like im going with skunk2
Old Jul 2, 2004 | 07:45 PM
purplevtec's Avatar
Default Re: (silver b18b1)
i second that opinion. I have a 00 gsr with the ingalls front kit and it squeaks like hell. Also adjusting them during alignment is a major PITA!
Old Jul 2, 2004 | 09:52 PM
IntegraBoy04's Avatar
Default Re: (purplevtec)
I have Skunk 2, and it's really nice. I got it off of eBay for 170. Can't beat that.
Old Jul 2, 2004 | 10:44 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
ok, i've got a DA. i've got H&R sports, KYB AGX, etc. Should I go with skunk2, or SPC? i'm kinda leaning towards SPC.
Old Jul 3, 2004 | 12:03 AM
g2homboi's Avatar
I've got ingalls on, they squeak but I bump the music to ignore the noise. Skunk does not make camber kits for DA. Try SPC, and then write a review up at g2ic.com, help us out.
Old Jul 3, 2004 | 01:02 AM
JFG Kevin's Avatar
Default Re: (g2homboi)
is the skunk2 camber kit hard to adjust?....or spc..kit
Old Jul 3, 2004 | 01:22 AM
Phoenix_ITR's Avatar
Default Re: (aznstyler119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">is the skunk2 camber kit hard to adjust?....or spc..kit</TD></TR></TABLE>
it's easy to adjust -- you don't even need to take the wheels off.
Old Jul 3, 2004 | 02:41 AM
JFG Kevin's Avatar
Default Re: (delinquent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent &raquo;</TD></TR><TR><TD CLASS="quote">
it's easy to adjust -- you don't even need to take the wheels off.</TD></TR></TABLE>
that sounds too easy now...hahaha..how is that possible...if it's that easy...should i even tak it to the alignment shop...=p...anywayz...should i just get the s2 camber kit?...or should i get somethin else...no more ingall fo me. i also just read somewhere that the s2 camber kit hit pittin the top of the frame makin big dent on the top... ...and also wonderin what's the differance between the newer and older s2 camber kits....and isn't the spc camber kit just a ball joint?
Old Jul 3, 2004 | 06:44 AM
The newer Skunk 2 kit is made a little bit better than the old one.
Old Jul 3, 2004 | 10:14 AM
wreckedmyteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I think I might get the OmniPower upper control arms, exact same as Skunk2 but for around $170.
Actually I'm also considering the OmniPower rear upper camber links, and also some sort of toe link like the ones from SRR. </TD></TR></TABLE>
I bought the omni-powers off ebay. Came out to be a little over 170. The control arms look great! They came with bolts and washers for the rear, but the bolts were way too long so I just used the washers and the stock bolts. Hopefully they won't pull out on me.
Old Jul 3, 2004 | 10:17 AM
oldskool teggy's Avatar
Default Re: BEST CAMBER KIT (wreckedmyteg)
i'd go with the omnipower too.. i have the sprint kit -+4 and the washer trick out back. pretty good, but omni kit is cheap for what they give you. quality seems good too
Old Jul 3, 2004 | 11:10 AM
joewhite's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2homboi &raquo;</TD></TR><TR><TD CLASS="quote">I've got ingalls on, they squeak but I bump the music to ignore the noise. Skunk does not make camber kits for DA. Try SPC, and then write a review up at g2ic.com, help us out.</TD></TR></TABLE>
that sucks well im on g2ic.com also i check out those SPC's thanks brutha
