How to take care of tein..or coilover
i'm hearing people havine their coilover gettin rusted out...is there anyway to provent it form happen or make it last longer?...maybe spring wd40 every oil change or just wippin it down??
I clean and protect mine every 7500 when i rotate my tires. I use some anti rust spray that i picked up at a marine store, but wd40 will work also. If you live in an area where they salt the roads, maybe put some anti seize on the threads, that should prevent them from rusting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">I clean and protect mine every 7500 when i rotate my tires. I use some anti rust spray that i picked up at a marine store, but wd40 will work also. If you live in an area where they salt the roads, maybe put some anti seize on the threads, that should prevent them from rusting.</TD></TR></TABLE>
The thing about using anti seize/wd40 is that it will force everything will stick to your dampers. I would use a silicon spray, or something that isnt sticky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">I just keep mine clean. I use a toothbrush and rags on them about once a month.</TD></TR></TABLE>Holy crap, come clean mines, I sprayed napa silicone spray on the upper bushing part. You know that rubber peice(JiC), but ive only cleaned the threads once so far and boy it sure was dirty.
gribbs
26
Apr 19, 2003 11:40 PM
...i got some of that at home...
