which motor mounts do i use and a b20/vtec engine swap???
Old Jul 1, 2004 | 11:47 PM
af1king1421's Avatar
Default which motor mounts do i use on a b20/vtec engine swap???
hello i was planning on doing a b20/vtec engine swap in my integra. i was going to use a b16a head and a b20 block and a ls tranny but i am confused on which motor mounts to use. do i use b16a or b20 or whatever the tranny is mounts??? and would this all be possible knowing that the head is obd1 and the block obd2. how would i make those obd's work together???
PLEASE HELP ME!!!
Old Jul 2, 2004 | 12:05 AM
3.504's Avatar
Default Re: which motor mounts do i use on a b20/vtec engine swap??? (af1king1421)
the mounts are the same, the main harness connector differences are the distributor, and injector pig tails.... as long as those match you're car harness, it'll all plug in (i.e. you have an obd1 car, and the head is obd1 and it has all the sensors in it, it'll all plug in)
irideslammed5021
May 13, 2007 06:41 PM
heyitzspikey
Jan 18, 2006 09:49 AM
allmota1.8
Sep 14, 2003 01:59 PM
