OBD-1 Conversion
Old Jul 1, 2004 | 08:07 PM
Mefain's Avatar
Default OBD-1 Conversion
i just pulled my SOHC obd-0 motor today, i have a b17 swap going in which is obd-1 if i completely remove the exisiting obd-0 harness and replace it with the obd-1 harness will everything work or do i have to change more things? someone please let me know asap....thank you in advance
Old Jul 1, 2004 | 08:10 PM
Origin's Avatar
Default Re: OBD-1 Conversion (Mefain)
it wont work. the integra harness wont mate with the rest of the car harness's. you would have to change all the wiring to integra, and who knows if that would even work. definately not worth it when you can spend less on just the conversion harness
Old Jul 1, 2004 | 08:42 PM
Mefain's Avatar
oh, well i guess ill have to get a new obd0 harness or redo mine, cause i think i messed it up pulling the SOHC today
Old Jul 1, 2004 | 09:13 PM
Mefain's Avatar
bump
Old Jul 1, 2004 | 09:28 PM
Origin's Avatar
Default Re: (Mefain)
how did you mess it up? if you have messed it up beyond repair just go to the junkyard and pull another one out. but more than likely you should be able to fix it, unless you hacked it up or something
Old Jul 1, 2004 | 09:37 PM
Mefain's Avatar
nope didnt cut nothing...but i got pissed off and just yanked on it, i think i may have just split some wires....ive got a guy thats gunna look at it 2morrow after work, so hopefully i wont need nething cept to add the wires for vtec and the 4 wire O2
Old Jul 1, 2004 | 09:47 PM
Origin's Avatar
yeah let him check it and make sure everything is still good. try to use that same harness, hopefully you didn't make yourself walk a longer road by yanking on it. if you split some wires, fix them and make sure to do it right the first time. i know all too well about hurrying through wiring and then having the car not start because of some silly wiring messup that i didn't catch in the beginning. good luck man.
Old Jul 2, 2004 | 05:01 AM
Mefain's Avatar
bump
Old Jul 2, 2004 | 06:30 AM
NCchris's Avatar
you will be a lot better off if you use the harness that came with the car or a good one fron the junkyard. swap rule #1 use the harness that comes with the car!
HTH
chris
Old Jul 2, 2004 | 10:20 AM
crx_88_si's Avatar
get a obd-0 to obd-1 adapter harness. add wires needed for vtec and extra o2 sensor. swap dizzy plugs and you're good to go.
you could, just use a b16a1 dizzy and intake manifold and stick w/ obd-0
Old Jul 2, 2004 | 12:06 PM
RuthlessEF-9's Avatar
Blown90Hatch is the sn and jason is his name
greatest quailty, way better than the bunkslang stuff
Old Jul 2, 2004 | 12:09 PM
SoulSurfer's Avatar
Default Re: (RuthlessEF-9)
Buy my conversion harness in the link below
slickrickauto
Texas -OK -LA (Sales)
Aug 9, 2008 06:36 PM
bobbyisking
Jul 7, 2008 09:22 AM
jisu009
Mar 26, 2004 01:13 PM
dingusjt
Jul 26, 2002 12:26 AM
