modded ITR 1/4 times?
Old Nov 19, 2001 | 11:59 AM
96 SOHC VTEC's Avatar
Default modded ITR 1/4 times?
My friend has a '00 Type R, and I was wondering with a good driver and the following mods, what kind of 1/4 times would he likely to get? Thanks
AEM CAI
DC JDM 4-1 header with 2.5' collector
Comptech 6.75 lb flywheel
Carsound high flow cat
B pipe adapter
NGK copper plugs
Magnecor 8.5mm wires
JDM 4.785 FD with + GS-R 5th gear
Toda clutch
Old Nov 19, 2001 | 12:13 PM
tjtruong's Avatar
New User
Default Re: modded ITR 1/4 times? (96 SOHC VTEC)
i'm guessing 14.0? around there.. can be better if driver is crazy good.
Old Nov 19, 2001 | 12:17 PM
bodykit=rice's Avatar
Default Re: modded ITR 1/4 times? (tjtruong)
15 something
Old Nov 19, 2001 | 12:19 PM
Striker's Avatar
New User
If he races in my area, at 2800 ft elevation w/ temperaturs around 60-65 f, he'd probably pull a mid 14. Maybe 14.45 14.65. It really depends on elevation and temperature though.
BTW, how does he like the Toda clutch? Do you know if it's really stiff? Any info would be great, thanks.
Old Nov 19, 2001 | 12:51 PM
Default Re: modded ITR 1/4 times? (Striker)
I don't know about the clutch, he is getting it put on this week, but once he does I will let you know. 15's? I wasn't thinking that high. Stock ITR's can do better than that. This would be in Orlando, Florida if ran.
[Modified by 96 SOHC VTEC, 9:54 PM 11/19/2001]
Old Nov 19, 2001 | 01:05 PM
Striker's Avatar
New User
If I'm not mistaken Orlando is pretty close to sea level. If he goes at night w/ temps around 55, he'd probably pull a low 14 and potentially 13.99. Do you know if he's planning on hitting up the track any time soon?
Old Nov 19, 2001 | 01:14 PM
Black SVT's Avatar
In 70 degree weather I ran the time in my sig with just a homemade CAI ,JDM 4-1 and a test pipe.That was on street tires with the interior out.
Old Nov 19, 2001 | 02:38 PM
EleanoR's Avatar
Default Re: modded ITR 1/4 times? (Dc2k-specR)
I am guessing your friend will run mid 14's but if he can drive high 13's is definitely possible on a cold night
Mike
Old Nov 19, 2001 | 02:40 PM
AWDSOME's Avatar
Default Re: modded ITR 1/4 times? (talkie25)
Low 14's.
Old Nov 19, 2001 | 02:47 PM
SpeedRacer00-667's Avatar
Default Re: modded ITR 1/4 times? (Hyper165)
definetly a mid to low 13 w/ that kind of work
good luck
Old Nov 19, 2001 | 03:01 PM
Cosworth's Avatar
Default Re: modded ITR 1/4 times? (SpeedRacer00-667)
Sorry, but not even close to mid 13's with those mods. He'll definitely hit low 14's or high 13's.
Old Nov 19, 2001 | 03:04 PM
Striker "Do you know if he's planning on hitting up the track any time soon?"
Well next time I go down to visit him we plan on hitting Orlando up with my Civic and his R, but I don't know when that will be.
Old Nov 19, 2001 | 03:05 PM
Mike
LMFAO! Think so?
Old Nov 19, 2001 | 03:37 PM
EleanoR's Avatar
Striker, tell 96 SOHC VTEC to get his "little" *** down here so we can hit the track!!!!!!!!!
LOL
Mike
Old Nov 19, 2001 | 03:45 PM
JoshRambo's Avatar
mod all you want. is the person a good driver is the question.
i have heard of people hitting low 14's with my mods and the best i have put down is 14.8. i'll admit i probably suck at driving. so it is mostly a driver race
Old Nov 19, 2001 | 04:19 PM
Maybe my car is "little" Talkie, but once I spray my 150shot of NOS you are going down!
Old Nov 19, 2001 | 04:29 PM
EleanoR's Avatar
Yes driver is probably 90% of the equation. Mods really wont help your times unless you can drive/launch your car properly at the strip. HTH
- Mike
Old Nov 20, 2001 | 06:42 AM
PM-Performance's Avatar
see my sig, i got less than that and im consistant low 13.8's now. prob can squeeze 13.7
its all about the driver. . . . . also without slicks theres no way that car will go that fast. street tires wont do **** for that car on the strip. im even having a problem with my slicks hooking right now.
Old Nov 20, 2001 | 07:34 AM
FAST94GSR's Avatar
New User
Default Re: modded ITR 1/4 times? (itr206)
If you guys come to Orlando, hit me up I live 15 min from the track. yea orlando is at sea level. I don't recommend running street tires though. With the colder weather traction is harder to get.
ITR41's Avatar
New User
I have a friend with not even close to that done to his car and ran a 13.9 but he had a traction bar(very good investment) I would say high 13's with a decent driver maybe get a mid 13 with a great driver
Old Nov 20, 2001 | 07:37 AM
MPH's Avatar
MPH
New User
Default Re: modded ITR 1/4 times? (ITR41)
JDM 4-1
Testpipe
2.5 Custom exhaust
Icebox
slicks
Everything else stock
13.77@100
Old Nov 20, 2001 | 08:34 AM
Striker's Avatar
New User
It all depends on elevation, temperature, and humidity... run your R's on a drag strip on top of the Colorado mountains at 85 degree temperatures (hypothetical) and then run them on a drag strip right next to the beach in northern California at night w/ 45 degree temperatures with no humidity (again hypothetical) and I'm sure you'll be quite impressed by the time difference.
mugenr#1011
Apr 23, 2009 07:44 PM
LvN
Mar 19, 2006 04:47 PM
BikeSpike
Jan 14, 2004 12:07 PM
Andres-eh2
Sep 17, 2003 09:46 AM
EleanoR
Dec 23, 2001 11:11 AM
