89 Accord LX Idle Fluctuating Problems
Old Jul 1, 2004 | 05:40 PM
vcolfari's Avatar
Default 89 Accord LX Idle Fluctuating Problems
I have been having a problem with a fluctuating idle that goes from 500-1500. I have had surging problems at stoplights when the AC is on. The idle will range from very high when the car is cold to approx. 500 at a stop (causing the car to shake and occasional stalling). I replaced spark plugs, fuel filters, carburetor, motor mounts. I would be grateful for any suggestions.
Old Jul 1, 2004 | 06:23 PM
Intense3.2's Avatar
Default Re: 89 Accord LX Idle Fluctuating Problems (vcolfari)
it might be that your alternator is not charging correctly... the ac sucks alot of power at idle. Check all your grounds before you out go buy a new alternator.
Old Jul 2, 2004 | 09:59 AM
vcolfari's Avatar
Default Re: 89 Accord LX Idle Fluctuating Problems (Intense2.2)
My mechanic checked the alternator and grounds. Any other suggestions?
Old Jul 2, 2004 | 11:13 AM
CaptainObvious's Avatar
I...as well as almost every other accord owner on this forum has had the same problem. Search function is your friend...but i'll save you some time. Check and clean your iacv (intake air control valve) or whatever its called...a few good sprays of card cleaner does the trick...and then if it stills idles rough (low) adjust the idle screw.
Dionili Securio
Aug 27, 2018 04:55 PM
bestofthe80s
May 7, 2017 05:21 PM
danny7560
Aug 21, 2014 01:14 AM
joeramirez
Aug 15, 2005 02:29 PM
Doeboy
Oct 18, 2003 11:26 AM
