Check engine light, won't let me rev past 3000.
Old Jul 1, 2004 | 05:19 PM
null.'s Avatar
Default Check engine light, won't let me rev past 3000.
Well my check engine light came on while i was driving then i felt a sudden bog and i wasn't able to go past 3000 rpms. got home turned on the engine again and the cel was gone and everything seemed fine. went to safeway picked up some groceries then tried to start the engine and it took awhile and it barely started. CEL came on again and i'm not able to past 3000 rpms. came home and my car won't start unless i keep cranking for a long time. i'm guessing it is my IAVC but could someone inform me how to fix it? this is my 91 civic hb daily driver DX. diagrams anything would help
Old Jul 1, 2004 | 05:21 PM
EL Vap133's Avatar
Default Re: Check engine light, won't let me rev past 3000. (egb18turbo)
Did you check for codes?
Old Jul 1, 2004 | 05:40 PM
null.'s Avatar
Default Re: Check engine light, won't let me rev past 3000. (EL Vap133)
well actually i never had cel codes thrown at me so i'm not inclined to decode them yet, although i tried learning here https://honda-tech.com/zerothread?id=682412
Old Jul 1, 2004 | 06:43 PM
null.'s Avatar
bump
Old Jul 1, 2004 | 07:16 PM
null.'s Avatar
ok i saw the ecu code and it blink 4 times really fast
Old Jul 1, 2004 | 07:26 PM
Fobtions's Avatar
that is your CKP, or crank position sensor. which is located in the distributor.
alot of time if this happens , you need a new distributor. unless you have done a dpfi-mpfi swap and your wiring messed up somehow,
Old Jul 1, 2004 | 07:43 PM
null.'s Avatar
Default Re: Check engine light, won't let me rev past 3000. (Fobtions)
yeah i took out my distributor cap and i don't know what it is called but that little magnetic thing small looks like lead that small thing it broke so i'm guessing that is why my timing is off. that is what you get for buying distributor caps at kragen
Old Jul 1, 2004 | 10:28 PM
Fobtions's Avatar
usually its the rotor that sucks from kragen, but good luck man
Old Jul 2, 2004 | 03:36 PM
null.'s Avatar
replaced the dizzy cap and rotor and still won't let me rev past 3000, i'm going to try to check out that sensor damn that code 4
Old Jul 2, 2004 | 05:52 PM
hahagasdcrx's Avatar
Sorry to say it but you need a new Dizzy. If that Pickup broke for the sensor, its usually cause by a screw or bolt that fell in your dizzy before you put the cap back on.
Old Jul 2, 2004 | 05:55 PM
null.'s Avatar
Default Re: Check engine light, won't let me rev past 3000. (hahagasdcrx)
ok so i would need a new distributor? i checked the wiring and got 450 ohms which is normal and check ecu and it was fine. yeah i'm guessing i would need a new dizzy because it takes awhile to start up also. but thanks for the help and hope you are right so i dont' waste my money
demo024
Feb 17, 2011 03:17 AM
hondavixen
Dec 15, 2008 05:08 PM
CaliRockrr
Nov 26, 2005 04:37 PM
rad_thundercat
Apr 21, 2004 08:20 PM
johnzm
Sep 13, 2002 02:39 PM
