Tech Question! ((Swap))
Old Jul 1, 2004 | 02:52 PM
UnspokenTruth's Avatar
Default Tech Question! ((Swap))
I have a 1987 CRX and I want to put a 88-91 SI motor in it. (1.6 SOHC Non--tec) Will I have to buy motor mounts or can I just use everythiing thing that is already there. This would be a big help! Thanks!
Old Jul 1, 2004 | 02:58 PM
kurinto's Avatar
Default Re: Tech Question! (UnspokenTruth)
I believe your stock mounts will work, you should check out http://www.redpepperracing.com/ its a board specifically for your generation crx.
Old Jul 1, 2004 | 03:02 PM
5litereater's Avatar
Default Re: Tech Question! (kurinto)
im almost positive ur mounts shoudl work. if not stock motor mounts for the si arent expensive (u could find them on here). also before starting a thread, use the search function. damn near everything you can think of has already been talked about. good luck man!
Old Jul 1, 2004 | 03:18 PM
beavis's Avatar
the motor should drop in with some wiring
Old Jul 1, 2004 | 03:24 PM
wtsexton's Avatar
Motor will not just drop in. Contact RPR on redpepperracing for information on how to swap in a newer style d-series.
badass civic
Jan 19, 2009 03:21 PM
ekoms31
Jun 1, 2004 09:19 AM
99sonicbluegsr
Mar 7, 2004 02:05 PM
