Valve adj in 1st gen b16
I was curious if the valve adjustment in the 1st gen b16's is the same as the valve adjustment in the 99 civic SI's or the Del Sol Vtecs, or if there is a different valve adjustment for the 1st gen B16's??? Any help would be greatly appreciated, and if there is a different valve adjustment, any idea what the specs are or the website where i can get it??
I sent you a PM, aka
It's the vtec supplement. Freak if you can't check your pm's just search for vtec supplement
https://honda-tech.com/zerothread?id=395679
if you download this you willl have the valve adjustment specs for a pre-obd b16...they may be the same, but i don't know.
