What Rims for a 1986 CRX ???
Since I don't know the bolt pattern, could someone tell me what rims fit a 86 CRX or the bolt pattern?
If anyone has pics of rims on a 86 CRX please post them, I'd like to see. I might be pickin up an 86 crx very soon.
thanks
thanks
So the Rotas SS would fit?
thanks
EDIT:
15X6.5 rotas SS?
And then what size tire 195/50-15 ?
thanks for the help, Yes I'm a noobie to CRXs and such
Modified by Bbasso at 5:20 PM 7/1/2004
thanks
EDIT:
15X6.5 rotas SS?
I'm trying to get the car cause my current beater needs too much and this CRX has under 90k on the clock and not a dent anywhere...
But actually I do like the look of them
So 195-50-15 should work, has anyone had them on their car? could someone post a pic of some wheels on a 1st gen crx ???
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">You like the look of the first gens? Even enough to mod them?
I love Crx's to death but would never touch a 1st gen</TD></TR></TABLE>
If you've ever had one you might understand a little better. I miss mine like crazy and wish i had never let it go, despite all its problems. That little thing could move........and it looked good too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote"> and not a dent anywhere...</TD></TR></TABLE>
im sure the front fenders have been repalced at least once before, they dont dent they shatter
I wouldn't go any bigger than 15" with standard offset. Don't get anything wider than a 6.5" rim or the tires will hit the rear fenders. Even at that, on my '86 I had to grind away the lip that most people roll with a bat. That's just my car though...
I'd post a pic, but my CRX is on 4 jackstands in the garage with no rear suspension and no powerplant.
If you want to run bigger wheels & tires, or significantly lower it, then get the genuine Mugen replica street body kit from Jamie Houseman - http://www.racegearbox.com.
Finally, there is nothing wrong with a 1G CRX. If you don't like the looks of them, good for you. At 1956lbs for a stock Si, they've got tons of performance potential with a DOHC swap and some suspension. The DX & HF's are even lighter.
In fact, being the owner of both generations of CRX, I prefer the 86 over the chunkier 90.
To each his own...
To each his own...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TJ »</TD></TR><TR><TD CLASS="quote">I wouldn't go any bigger than 15" with standard offset. Don't get anything wider than a 6.5" rim or the tires will hit the rear fenders. Even at that, on my '86 I had to grind away the lip that most people roll with a bat. That's just my car though...
same here I owned an 86 and miss it still to this day. I love my 89 CRX but there's something about 1st gens ....
To each his own...
To each his own...
To each his own...</TD></TR></TABLE>
........Good info.........and I agree!
I agree I love my 87 DX at 1817lbs stock it doesn't take much to make it move. Once I get the time shes going FI.
8307 posts on <U>HONDAtech</U> and you dont know the civic bolt pattern
Damn look at my post at the time.
4x100MM
All Civic's* have the same bolt pattern and same off set.
A rim that will fit a 1989 CRX would fit a 86 CRX
A rim that will fit a 2000 Civic would fit a 86 CRX
Shall I break it down more?
* Not sure if that would include 1st and 2nd gen civic's
4x100MM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton »</TD></TR><TR><TD CLASS="quote">* Not sure if that would include 1st and 2nd gen civic's</TD></TR></TABLE>
That bolt pattern is different. And its an odd one too. I just can't remember exactly
jdmef8vtec
27
Mar 1, 2007 07:57 AM
effinnwackk
18
Jul 12, 2005 07:45 AM
