Portflow inners what retainers?
use portflow.
i saw something on here a while ago that said " i dont have the money to build it right, but i'll get the money somehow to build it TWICE!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. »</TD></TR><TR><TD CLASS="quote">also, upgrade your retainers
stiff springs and oe retainers can lead to shattered retainers. </TD></TR></TABLE> I got this from a post further down more...... i would change them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone »</TD></TR><TR><TD CLASS="quote">use portflow.
i saw something on here a while ago that said " i dont have the money to build it right, but i'll get the money somehow to build it TWICE!"</TD></TR></TABLE> famous words from OMNIMAN
i heard titanium retainers dont last long. The main goal of my project is longevity and reliebality.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">i heard titanium retainers dont last long. The main goal of my project is longevity and reliebality.</TD></TR></TABLE>
bump
bump
FYI im running a ctr intake cam now.
Will be swapping out for cams similar lift just a lot more duration......want more MIDRANGE for putting around town.
8200 will be my redline.
The cams are Buddy Club Spec 3+.
It seems like even complete stock valvetrain would suffice with these cams. I heard springs only bind from extra lift. Ive never heard of springs binding from duration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">The main goal of my project is longevity and reliebality.</TD></TR></TABLE>
Then leave it internally stock and work on flow: intake header/exhaust/(pullies if necessary) and then Tune the A/F with Hondata or another EMS. Just keep everything OEM and you will have a good combo as long as you don't spin it to 15K or whatever.
BTW longer duration/overlap usually puts the tq/Hp curves higher in the RPM band. so you should consider that with your 8200 rpm limit and cam selection
the Pirate
the Pirate
ive seen dyno charts comparing ctr cams to the buddy club and they kill the ctrs in the mid range. i already have all the bolt ons tuned with a v-afc.
AEM ITR CAI
STR TB
OBD-1 harness
JDM 4-1
Skunk 2 IM
No CAT or P/S
Greddy SP exhaust
CTR intake cam/GSR exhaust
JDM b18c SIR-g Block
B and M fuel Regulator tuned to 52psi
Check sig for power and times
AEM ITR CAI
STR TB
OBD-1 harness
JDM 4-1
Skunk 2 IM
No CAT or P/S
Greddy SP exhaust
how much is it for ITR retainers.....where could i get these?
i heard gsr/itr outers is the same.
Port flow inners are only 80bucks
If you want to go with portflow inners, then do it if you want. It's really not needed. Especially running Honda OEM cams, and redine to 8k. It is pretty sufficient staying stock type r valvetrain
Go to your local acura dealer parts dept. or acuraautomotiveparts.com
Does anyone know if i spelled the site out correct
jeremy.
Oct 21, 2003 09:05 PM
