GT28RS on HKS or Greddy Manifold and A/C ATTN:CIVICPOWER
I need to know if running a GT28RS on a B-series HKS or Greddy manifold clears the A/C. Looking to make sure so that I can make decisions now for future upgrade paths.
TIA
Josh
TIA
Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captian_Honda »</TD></TR><TR><TD CLASS="quote">what stlye flange is the manifold?
The GT28RS uses a 25 but you can order a T3 style housing from ATP</TD></TR></TABLE>
the manifold uses a t25 style flange which fits perfectly with the greddy manifold...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
Can anyone confirm this? If so I'm gonna buy the gt28rs and slap that onto my greddy manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg »</TD></TR><TR><TD CLASS="quote">
Can anyone confirm this? If so I'm gonna buy the gt28rs and slap that onto my greddy manifold.</TD></TR></TABLE>
it will bolt up.
im wondering if there will be any block clearence issues.
it will bolt up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIboost »</TD></TR><TR><TD CLASS="quote">Is this true for the D series greddy manifold also?</TD></TR></TABLE>
edit..
i posted info that wasnt true.
edited as to not spread bad info
anyone have a gt28rs and a greddy manifold laying around?
id like to see it bolted up to a d block.
i hear there may be block clearences (ie, you may need to shave down the block)
also interested if a 2.5" DP and still be able to keep a/c is doable.
Modified by llewsirc at 4:03 AM 10/10/2005
edit..
The GT28RS uses the same Garrett T25/T28 flange found on the Greddy D and B series turbo manifolds so yes it will work. Someone on turbod16.com matted a Greddy 18G TDO5H turbo to a Greddy D series manifold and the fit was perfect so I would assume they share the same flanges.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">it is true ONLY for the d series manifold.
d series greddy manifold = tdo4h flange
b series greddy manifold = tdo5 flange
gt28rs = tdo4 flange (also available in a t3 flange, but a t3 will not work with any greddy manifold)
this is entirely incorrect. the gt28rs, and both the d and b-series greddy manifolds use t2 flanges, not td04 or td05 flanges. the t2 flanges are the same as what are found in the nissan sr20 t25/t28's. the greddy kits do use td04 and td05 mitsubishi INTERNALS in the turbos, but the flanges are for nissan/garret t2 housings, not mitsubishi housings.
</TD></TR></TABLE>this is entirely incorrect. the gt28rs, and both the d and b-series greddy manifolds use t2 flanges, not td04 or td05 flanges. the t2 flanges are the same as what are found in the nissan sr20 t25/t28's. the greddy kits do use td04 and td05 mitsubishi INTERNALS in the turbos, but the flanges are for nissan/garret t2 housings, not mitsubishi housings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r_wiggum01 »</TD></TR><TR><TD CLASS="quote">
this is entirely incorrect. the gt28rs, and both the d and b-series greddy manifolds use t2 flanges, not td04 or td05 flanges. the t2 flanges are the same as what are found in the nissan sr20 t25/t28's. the greddy kits do use td04 and td05 mitsubishi INTERNALS in the turbos, but the flanges are for nissan/garret t2 housings, not mitsubishi housings.</TD></TR></TABLE>
i mst have gotten some bad info.
i edited my post
thanks for the info.
i edited my post
GT28RS with HKS B-series manifold. Clears block with no problems, but the V-band adapter I am using along with the 3" DP will not clear A/C. There will be no room for a filter either unless you run the compressor at the driver's side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">bump for block clearance issues</TD></TR></TABLE>
yep. anyone with info... GOOD / TRUE info please enlighten me
i im'd a few people on here about it, as soon as i get a response ill post it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctownintegra »</TD></TR><TR><TD CLASS="quote">Bump for the PS mount question.</TD></TR></TABLE>
he is a polishing *****
but lets stay on topic
but lets stay on topic</TD></TR></TABLE>
LOL, yup, polished stock piece
but lets stay on topic</TD></TR></TABLE>LOL, yup, polished stock piece
