b20....header choices....best header? 4-1 or 4-2-1?
Old Jul 1, 2004 | 08:26 AM
bambam's Avatar
Default b20....header choices....best header? 4-1 or 4-2-1?
What do you guys think of a header for my b20? I'm currently running the 90-91 integra manifold (worst b-series E.M. EVER made). It is restricting the flow of my b20 WAY too much. I have the 2.5 exhaust and aem cai. What should i do for a header? I was thinking a 4-2-1 because my greatest power is from low to mid and i thought the 4-2-1 would compliment that but after thinking, the b20 has a greater airflow output so shouldn't i get a 4-1 to compensate? I'm thinking about a 4-1 with a 2.5' outlet. Whaddya think?
Old Jul 1, 2004 | 08:32 AM
UNDER PRESSURE's Avatar
Default Re: b20....header choices....best header? 4-1 or 4-2-1? (bambam)
First of all are you ever going to slap a vtec head on the block? If you are I would go with 4-1 piece, great top end. If your planning on staying B20 I would go 4-2-1, good low end and mid range.
Old Jul 1, 2004 | 08:35 AM
itr crx's Avatar
Go with the 4-1 header good for top end power , I have the jdm itr 4-1 header in my cr-x..
Old Jul 1, 2004 | 08:39 AM
APEX CRX's Avatar
Default Re: b20....header choices....best header? 4-1 or 4-2-1? (UNDER PRESSURE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE &raquo;</TD></TR><TR><TD CLASS="quote">First of all are you ever going to slap a vtec head on the block? If you are I would go with 4-1 piece, great top end. If your planning on staying B20 I would go 4-2-1, good low end and mid range.</TD></TR></TABLE>
YUP. depends if you are going to swap the head in the future or not
bambam's Avatar
i'm staying non-vtec looking to get near 160-170 whp. The header would be for a b18 and the b20 has a greater output so wouldn't i need a 4-1 to compensate for that?
Also...doesn't the jdm itr header only fit the vtec heads or does it fit the non vtec heads as well?
Old Jul 1, 2004 | 09:04 AM
Default Re: (bambam)
I would go 4-2-1 because your going to stay non vtec, and the crv power plant has no power up top so what you want is good low and mid range.
Old Jul 1, 2004 | 09:10 AM
Ef-er's Avatar
I've got a non vtec b20 in my crx and ive got a greddy 4-2-1. it gets my
if u wanna go 4-1 u might need to modify your cross member plus it'll sit DAMN low (bottom out issues)
Old Jul 1, 2004 | 07:49 PM
bambam's Avatar
Default Re: (UNDER PRESSURE)
the thing is...
the b20 puts out a higher airflow output than a b18. I've been told by numerous tuners as well as other people here that a 4-1 header would be better to compensate for the 4-2-1's restrictive design for a b20. I've been told that a 4-2-1 aftermarket header will still restrict the flow of a non vtec b20. does anyone have any experience with both or either on a b20?
Old Jul 1, 2004 | 08:03 PM
non's Avatar
non
I run Kamikaze's header in the 2.5in option collector. Makes good power up top
Old Jul 3, 2004 | 07:28 AM
bambam's Avatar
well...i just bought a header and a cat. i bought the jdm 4-1 ITR header with a 2.5' collector. The cat is a catco 2.5' inlet and outlet...this will all match up nice with my 2.5 piping and 2.5 muffler. thanx for ur guys help!
Old Jul 3, 2004 | 07:40 AM
green91's Avatar
how big off a difference did it make
Old Jul 4, 2004 | 01:54 PM
bambam's Avatar
Default Re: (green91)
ill tell you when i get it installed next week. I can install the header myself...but i know ill have trouble lining it up with the stock crx cat because as you know the jdm itr header has a 2.5 collector/outlet. So, i'll have to wait till next week when i can pay to get the 2.5 cat welded up to my already existing 2.5 piping. Then i'll install the header myself.
Old Jul 4, 2004 | 02:02 PM
Full Race A6's Avatar
**** welding, muffler cement and a clamp lol
ANyways, whyd you go with the jdm itr 4-1?
Why not go aftermarket? I just thought that header was so high priced because people loathing JDM and didnt think its performance would be any good
Old Jul 4, 2004 | 02:31 PM
bambam's Avatar
it's great i think it's the same design as the dc sports jdm 4-1. i believe most of the 4-1 b-series headers are designed after the jdm itr header....i didn't pay that much for it...only $150. i got it because it has the 2.5' collector....which is needed for the b20's displacement.
i really hope u were kidding about the cement and clamp thing....that stuff has no place on my car...i do everything clean and right the first time. i paid $265 for my 2.5 mandrel bent catback from a reputable custom exhaust/turbo shop over here. Some people said they could have done it for like $100 bux or something but i got what i payed for...not some crushed bent, clamped, crooked piping from an inexperienced shop.
Old Jul 4, 2004 | 03:33 PM
I got my madrel bent 2.25 for $140 no clamps
Also, you know you can turn around and sell the header and make an easy $100 profit?
My brother sold his for almost 300 worth of parts and I see them going for 250 all the time
Old Jul 5, 2004 | 02:36 PM
bambam's Avatar
Default Re: (W O T)
I really don't want to sell the header...I just bought it....lol
JDM91EF2
Mar 27, 2007 07:50 AM
B20inDCinLBC
Sep 21, 2006 05:02 PM
rex_racer728
Oct 20, 2005 10:59 AM
No-Gi
Sep 24, 2002 01:11 PM
