F22C crank in K20a??
Old Jul 1, 2004 | 08:18 AM
noslocvc's Avatar
Default F22C crank in K20a??
hey guys,
rumor has it the f20c crank will work in a k24 block to slightly destroke it, improving the r/s ratio, rod angle & length, lowering piston speeds, safely raising the redline, and ultimately making a more reliable hybrid engine.
so my question is THEORETICALLY, since that would work, let's try the opposite: would a f22c crank work in a k20a block to increase displacement??
i know there would be a difference:
f20c crank in k24= roughly 2.3L
f22c crank in k20= roughly 2.2L
question is, which motor would be more reliable & have better output??
now i know the k20a block is a perfect square (86mm stroke x 86mm bore) leading to an almost perfect balance between torque and power/revving, so hopefully by increasing displacement would it have more torque and more power also.
feel free to weigh in w/ your opinions, but try to keep it on topic
(i'm a noob when it comes to calculating compression #'s, ratios, and all that ish, so please don't ask me to prove it)
Old Jul 1, 2004 | 08:39 AM
6SPD_EK's Avatar
Default Re: F22C crank in K20a?? (noslocvc)
don't think so b/c k24 block is 19.7mm higher than k20a...without that height i think you will have some major piston - valve contact (although i could be wrong)
and that s2000 crank you talk about (to destroke the k24) is out of the 2.2L '04 s2000 f22c not the f20c
edit - i think if you did stroke a k20a block you could easily ruin the reliability of the motor & the capability to rev to 8000+ all day
BTW - PLEASE NOTE I heard you can run into problems just dropping in a 04 s2k crank in a k24 block...issues with it not fitting perfectly (if it can be done how come nobody has done it with success.....yet)
Modified by adirondackR at 12:54 PM 7/1/2004
Old Jun 30, 2005 | 07:19 AM
EFDawg's Avatar
Default Re: F22C crank in K20a?? (adirondackR)
Ron at IPS is working on it as we speak.
Old Jun 30, 2005 | 07:28 AM
chameleon's Avatar
Default Re: F22C crank in K20a?? (DC5Dawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5Dawg &raquo;</TD></TR><TR><TD CLASS="quote">Ron at IPS is working on it as we speak.</TD></TR></TABLE>
word to momma! check out the related thread over at k20 international ..
http://www.k20a.org/forum/showthread.php?t=3775
nemesis.442
17
May 7, 2012 12:34 PM
vtec-gorilla
Nov 26, 2006 05:19 PM
