V-AFC II on an LS engine??
Old Jul 1, 2004 | 06:45 AM
MarkAngelo's Avatar
Default V-AFC II on an LS engine??
what's up guys.. I was wondering if I can run a vafc II on an LS engine?? Does it have the setup for the engine?? I know that in the program mode, it asks what engine you are running. I was wondering if the VAFC has the non vtec b18 ls motor in the menu... thanks!
Mark
Old Jul 1, 2004 | 06:49 AM
MarkAngelo's Avatar
Default Re: V-AFC II on an LS engine?? (MarkAngelo)
bump!
Old Jul 1, 2004 | 06:56 AM
brautzen's Avatar
Yeah, you can run a vafc on a non-vtec engine. The vtec portion of the harness won't be hooked up, that's all. At least with the vafcI, it had more points for the air/fuel curve, so some people prefered it to the safcI. I don't know if there is a difference between the safcII/vafcII with their a/f set points, and am too lazy to check. But as to your question of wheter it will work or not, it will
Old Jul 1, 2004 | 10:53 AM
LSTEG96's Avatar
Default Re: V-AFC II on an LS engine?? (brautzen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brautzen &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, you can run a vafc on a non-vtec engine. The vtec portion of the harness won't be hooked up, that's all. At least with the vafcI, it had more points for the air/fuel curve, so some people prefered it to the safcI. I don't know if there is a difference between the safcII/vafcII with their a/f set points, and am too lazy to check. But as to your question of wheter it will work or not, it will</TD></TR></TABLE>
how many points did the first version have? cause the vafc2 has a bunch.
Old Jul 1, 2004 | 10:55 AM
B2FiNiTY's Avatar
Default Re: V-AFC II on an LS engine?? (LSTEG96)
Half the points of the new one.
Honda_8987
Engine Management and Tuning
Jun 22, 2011 04:12 AM
Traser
Nov 17, 2006 11:30 AM
ej2civic
Feb 6, 2005 06:49 AM
sleepin91teg
Mar 25, 2004 12:27 AM
