what quaife lsd will work in cable s1 tranny
Old Jul 1, 2004 | 06:18 AM
jessevtec's Avatar
Default what quaife lsd will work in cable s1 tranny
like topic says, thanks
Old Jul 1, 2004 | 08:17 AM
Eggman's Avatar
Default Re: what quaife lsd will work in cable s1 tranny (jessevtec)
90-91 Integra one.
92-93 Integra and 94+ Integra will work too, but you'd have to change out quite a bit of stuff...
part numbers...
http://www.exospeed.com/transmission/quaife.htm
Old Jul 2, 2004 | 02:39 PM
hughesl's Avatar
Honda - Civic Si 1999-2001 VTEC dohc (B16) Part Number 60.309.160
http://www.quaifeamerica.com
They don't split it out by 90-91 teg or 92-93. There is one application for the 90-2000. That application happens to be the same one I gave you above. I have the S1 tranny with the quaife diff listed above. It is basically the one for B16 applications. When I was looking for an LSD people on Honda tech told me quaife did not make a diff for our application. I did a little research and decided to order one any way. I used the bearings, speedo gear, and final drive gear from my S1 tranny. There are two small casting fins on the tranny case you may have to file a little, because the quaife is a little fatter. Other than that it dropped right in. So far I am very happy with the quaife product.
Good luck
Old Jul 2, 2004 | 02:45 PM
krazie1's Avatar
BANNED
Default Re: what quaife lsd will work in cable s1 tranny (hughesl)
wow great reply bro
and well hope I don't have problems with my Kaaz LSD like that
as I got the one for a 90-91 integra so I was told by the seller
will be install soon and I will cross my fingers
Old Jul 4, 2004 | 02:59 AM
jessevtec's Avatar
thanks for the info
mycrx7
23
Jul 13, 2010 10:41 PM
88 EF Hatch
15
Jan 3, 2009 09:18 AM
racin_jayson
Apr 5, 2007 12:36 PM
LSV_REX
Jul 5, 2006 05:50 PM
sherfield2002
Dec 21, 2003 12:47 PM
