Can I run Sk2's stage 2 with this???
I belive I have very little room for error in my set-up cause of the ******* machine shop shaving my head .33 thou but anyway I just hit 195hp ttw with CTR cams I want more so I was thinking of getting Skunk2 stage 2's with springs and retainers I'm getting a really really good deal on them so that's why I want them bad, I'm running in the All motor street events and I need more power for the 1/4!
My set-up is GSR block with PR3 pistons
ITR head shaved .33thou stock head gasket. I will clay the motor just to be sure but if anyone thinks I can't run them cause of clearence issues I would like to know before I start ripping **** of my motor which runs really good.
TIA guys Rob
TIA guys Rob
i have an ls/vtec that just had pr3s installed, gsr head (milled) and s2 stage 2s. it only ran for about one minute (due to someother problems) and it ran fine. i later found out that my builder did not clay the motor, he just relied on his finite wisdom as a novice honda experience. that being said, you will PROBABLY be fine, but you said that you were going to clay the motor anyway so no worries.
pootie.teng
17
Feb 20, 2007 08:06 AM
