shimmed oil pump & cam seals leaking
Old Jul 1, 2004 | 01:17 AM
Rusty Shackleferd's Avatar
Default shimmed oil pump & cam seals leaking
I put a .110 shim in my oil pump. I searched and found some people saying that the added oil pressure will blow seals. Just wondering if anyone has ran in to that problem of too much oil pressure pushing out the cam seals.
Old Jul 1, 2004 | 05:02 AM
EE_Chris's Avatar
Default Re: shimmed oil pump & cam seals leaking (Rusty Shackleferd)
I've not heard that shimming the oil pump increases oil pressure to the point of seal failure, however I've read that you should use a .030" washer and you're close to 4x that.
Something to think about....
Old Nov 29, 2004 | 11:58 AM
Jared's Avatar
the cam seals have a nice drain hole right behind them, in most cases too much oil pressure will push out the front crank seal first.
tony_2018
Sep 4, 2014 07:18 AM
eg-gsr423
Oct 27, 2009 08:57 AM
wernhersey
Nov 13, 2008 08:14 AM
Power Rev Racing
22
Nov 8, 2005 03:45 PM
solorexer
Sep 3, 2004 06:01 PM
