90-93 XSi cluster how to.
Old Jul 1, 2004 | 12:34 AM
rjay8604's Avatar
Default 90-93 XSi cluster how to.
Hey guys. I got bought a jdm DA teg gauge cluster. My friend (nickgmiller0404) is gone at the USNA so i got his cluster. I took the USDM speedometer put it with the jdm tach and voila. the best of both worlds. Well here's a little how to and some pics. this is in a 91 civic dx hatch.
the cluster
the wiring
harness complete.
cluster in and working.
how to wire the integra connectors. yeah i did it on PAINT.
Modified by rjay8604 at 9:54 AM 7/1/2004
Old Jul 1, 2004 | 04:21 AM
gac_gonejeepin's Avatar
Default Re: 90-93 XSi cluster how to. (rjay8604)
me likey! that looks pretty good. any better shots of it mounted in the bezel of your dash?
---gabriel
Old Jul 1, 2004 | 06:38 AM
Kyo Babic's Avatar
Default Re: 90-93 XSi cluster how to. (gac_gonejeepin)
Nice job man ...did ya get the cluster fit in the dash yet? cuz thats the pain in *** part, the wiring is the fun part!
Old Jul 1, 2004 | 08:47 PM
rjay8604's Avatar
here's one mounted in bezel. took me all damn day, oh well all works and fits now.
hey kyo babic, i ended making some brackets for it, plus its fits in there so snug it won't really move around. I had to cut a lot to make clearance for the hazard and dimmer and defrost switches. did you have to. thanx guys.
Old Dec 8, 2004 | 12:15 PM
89dxhunchback's Avatar
You must use a 90-91 civic "cluster hood" on the 88-89s. The 90-91CRX cluster hood will not work on a civic.
Modified by 89dxhunchback at 12:34 AM 12/10/2004
Old Dec 8, 2004 | 12:32 PM
LSVTEC 91 Civic's Avatar
Banned
So, I take it the DA cluster is VSS?
Old Apr 13, 2005 | 09:45 PM
rjay8604's Avatar
Default Re: (LSVTEC 91 Civic)
No its cable speedo, thats why i really liked it.
Old Apr 17, 2005 | 05:34 PM
hybridpatient95's Avatar
i put mine in today... its just i forgot to get the one clip with the cluster.. can i use one crx clip and one teg clip?
Old Apr 17, 2005 | 05:35 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (frankenfiend 04)
hey man, this seem like a good writeup but several of your pics dont work now
Old Apr 17, 2005 | 07:08 PM
mawkiemarc's Avatar
is there anyone or anywhere i could pick on of those up? im lookin to know how fast im goin instead of only seein 120mph...
Old Apr 17, 2005 | 08:25 PM
rjay8604's Avatar
Default Re: (mawkiemarc)
i got mine on ebay for about $70. You can also use a 92-93 Integra GSR becuase those already have the MPH speedo and the 8000 redline. Mine has a USDM speedo for a LS teg.
If you guys really need i can put those pics back up. I just left the important ones, the diagram is the important one, the others just show me taping up the wiring.
Old Apr 18, 2005 | 03:55 PM
mawkiemarc's Avatar
alright thanks good lookin man!! what did you search under on ebay?......
Old Apr 24, 2005 | 03:49 PM
umm is the wiring the same on the 91 hf? cuz it seems alittle different.. and can you get the pic of the wiring to work again or email it to me cuz i need help my blinkers dont work, voltage light, checkengine one, the onyl one that works is the high beam and right side of the cluster glow lol
Old Apr 24, 2005 | 05:28 PM
rjay8604's Avatar
I'm guessing the CRX HF wiring would be near identical. Did you pin the wires up like i show in that diagram? Also trace the printed circuit and you can see which wire goes to what light.
Old Apr 24, 2005 | 06:53 PM
yea i def have to get a wiring diagram..
Old Apr 24, 2005 | 08:31 PM
nsone's Avatar
Cancel that question.
In the picture it looks like the fuel guage is blocked off a bit, any way to make it show for? just an eye sore that's all.
Modified by nsone at 9:47 PM 4/24/2005
Old Apr 24, 2005 | 09:51 PM
rjay8604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">yea i def have to get a wiring diagram.. </TD></TR></TABLE>
Use that diagram above, just match the wires into the integra connectors like i have shown in that diagram. I labeled which ones need to extend. If you make the connectors like that diagram it should work.
Old Apr 24, 2005 | 09:57 PM
rjay8604's Avatar
Default Re: 90-93 XSi cluster how to. (nsone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsone &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by nsone at 9:47 PM 4/24/2005</TD></TR></TABLE>
You could cut the bezel. It is easy to see if you just move your head to the left a little you can see the rest of the gauge. I like it because it matches the style and time period of the EF cluster but has a higher speedo, higher redline, looks much better, and light up a nice clean white at night instead of dingy yellow.
Old Apr 24, 2005 | 11:06 PM
tRex99's Avatar
actaully if i were you i would cut the bezel...u know the bits they use to cut out door *****? u can get sizes that are different. Go get one that is the same size or real close to those last 2 guages and cut out the other half moon of it..itd look real clean too. get a fingernail file, sand paper, or even regualr file and file up the edges where u cut to make it nice and smooth...i bet it'd look real sweet...
also, im getting a hydro tranny i notices someone said something about the VSS cluster and the cable cluster...ok well me haveing a cable cluster but a hydro tranny, how does this work? do i use the cable connector and just bolt it on the hydro tranny like the cable would??
Old Apr 24, 2005 | 11:12 PM
nsone's Avatar
Thanks for reply, also.. foremost, Thanks for the writeup and diagram.
I have read the other HowTo here: http://www.4thgenerationcivic.com/ho...ket-Custom.htm
I also noticed this on the page:
NOTE: I am installing an integra dash so I can't fully explain how to install the cluster in the stock dash other than you cant use the clear shield and you have to trim the hood and the inside of the dash to make it fit.
Old Apr 25, 2005 | 03:18 AM
i cant just use 1 crx connecter and 1 integra connecter?
Old Apr 25, 2005 | 10:34 AM
rjay8604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">i cant just use 1 crx connecter and 1 integra connecter?</TD></TR></TABLE> No, use both integra connectors, the crx one shouldn't even fit.
The cluster fits in real snug, the clear shield stays and fits real nicely. The one major problem is you need to cut two chunks off the bottom of the cluster to fit the hazard and dimmer switches. But the cluster wedges in the stock location rather easily and you just need to cut and remove a little material.
Old Apr 25, 2005 | 11:28 AM
it def fit.. and my blinkers worked and all... its just the right side plug didnt fit
Old Apr 25, 2005 | 12:12 PM
rjay8604's Avatar
For that other plug you are going to need an integra plug.
Go to th junkyard and just cut off an integra connector.
Old Apr 25, 2005 | 03:55 PM
i got both plugs.. can post another pic of the wiring.. the 2 dont help that much
