tach jumps around
Old Jun 30, 2004 | 10:05 PM
b18c5hatchie
Guest
Posts: n/a
Default tach jumps around
my tach jumps around 4500-8200 rpm i already changed ingnitor, and coil.
but no luck. i tried another distubitor and it throws code 15. need help
anything would help.
Old Jun 30, 2004 | 10:36 PM
crazyitr's Avatar
Default Re: tach jumps around (b18c5hatchie)
I had the same problem. There is a wire under your cap that is the pickup for the tach. It needs to be isolated or wrapped. If it is arcing, you will have this problem. It's a easy fix.
Old Jul 1, 2004 | 01:51 AM
RedZone's Avatar
Default Re: tach jumps around (crazyitr)
its the ignition output wire from the ecu to the igniter in the distributor......just make sure all the wires on the igniter in the distributor are tightly connected to the terminals. the igniter is the module in the distributor that has 4 wires going to it .....3 on top and one on the side. the one on the side is the ignition output signal wire...make sure its nice and tight and you should be fine.
Old Jul 2, 2004 | 06:59 PM
b18c5hatchie
Guest
Posts: n/a
Default Re: tach jumps around (RedZone)
thanks for the help it came in handy it fixed the problem
bertsb18hatch
Apr 19, 2008 08:14 AM
4door-r
Apr 23, 2004 04:01 PM
its WANG yoO
Dec 9, 2003 09:19 AM
DCx2xNV
Mar 4, 2002 10:45 AM
