crank and pulley problems
Old Jun 30, 2004 | 09:46 PM
haophat's Avatar
Default crank and pulley problems
so here is my situation I had not tightned my pulley enough and the bolt came loose and sheared the key and key way on the crank ugh! so I was thinking about trying to stick a new key and pulley on thre and lock tite the bastard and maybe add a little tack weld to sure it on, but just a lil so if needed i can air chisel it off.
do you think the new key and lock tite will do? I am afraid if i weld it it may throw off the crank at high rpm's?? and if it is off balance how much vibration would occur? I really dont want to pull the engine and crank out!
civikdude
Feb 13, 2009 02:17 PM
bseriescrxsi
Mar 31, 2008 12:11 PM
DJNauTicz
May 2, 2007 11:31 AM
asefi944
Apr 11, 2005 02:26 PM
HonCiv
12
Nov 15, 2002 10:01 AM
