What injectors for built ls/vtec?
Old Jun 30, 2004 | 09:34 PM
JDM-FAN's Avatar
Default What injectors for built ls/vtec?
About 10 months ago i bough a Civic Couple with a fully built ls/vtec, but it has stock injectors, so obviously its running lean. So any suggested injector size to run with these mods.
B18b block bored 10 over with 11.8:1 je pistons and eagle rods, shaved B16a head, port and polished with three angle valve job, crower stage 2 cams, crower springs and retainers, 70mm BBk tb port matched to a skunk2 manifold port matched to head, Apexi 4-2-1 header, tanabe cat-back and CTR ECU.
Also soon i am going to probably get either a Fields or an Apexi Vtec contoller.
Old Jun 30, 2004 | 09:41 PM
JDMotive's Avatar
Default Re: What injectors for built ls/vtec? (JDMw00ter)
RC 310cc's should work good for your setup.Just make sure you have something to trim them down at idle,or itll be a little lumpy.
Old Jul 1, 2004 | 07:12 AM
spartacus087's Avatar
why not just go with dsm 450s they leave with ALOT of room and they are very cheap and available.
jdm 1080p
Jun 8, 2012 03:59 PM
2n-chilli
11
Apr 15, 2011 07:35 AM
baam
Sep 13, 2005 05:18 PM
RI_TM
Mar 17, 2005 09:12 PM
