will a d16z6 mind revving to 9k with just zex valvetrain, eagle rods and wiseco pistons?
Old Jun 30, 2004 | 09:28 PM
z6's Avatar
z6
Default will a d16z6 mind revving to 9k with just zex valvetrain, eagle rods and wiseco pistons?
or will it blow up in my face?
9000rmp assuming about 350-375hp
Old Jun 30, 2004 | 09:35 PM
JDMotive's Avatar
Default Re: will a d16z6 mind revving to 9k with just zex valvetrain, eagle rods and wiseco pistons? (z6)
If youve got eagle rods and zex valvetrain,you will be good to at least 9k.Ive done 8k on a stock bottom end,though i wouldnt do that everyday,as the stock rods are very weak.You'll be ok though.
Old Jun 30, 2004 | 11:04 PM
Kendall's Avatar
Do you have a cam that will allow the car to make power that high? If not then there is no reason in the world to rev that high. Also, what in the world do you have done to a Z6 that will make 350 horsepower?
Old Jul 1, 2004 | 07:30 AM
z6's Avatar
z6
^nothing, i was simply interested in making custom grind cams that have a very high torque peak(like maby 8200-8500 rpm) and i said 350 hp because spinning a bottom end at 9k with 50hp load is quite a different senario than 9k at 350 hp
Old Jul 1, 2004 | 05:29 PM
B18 CYA's Avatar
******* n00b..... **** ur z6, go get a real motor!
Old Jul 1, 2004 | 06:04 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (c2nap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c2nap &raquo;</TD></TR><TR><TD CLASS="quote">******* n00b..... **** ur z6, go get a real motor!</TD></TR></TABLE>
STFU
fatboys_ef9
Oct 25, 2009 06:07 PM
eg:R
Nov 16, 2007 08:54 AM
thumbtack
Nov 10, 2005 03:55 AM
quicksol95
14
Sep 20, 2004 06:38 PM
liam821
Aug 7, 2003 09:52 AM
