OBD0-OBD1
ya i have a 89 crx si and im dropping a 93 ls engine and i have the crx wire harness in already so i need the obd0-obd1 conversion.. what all do i have to do... i got the conversion harness so what now...
didn't the distributor come with the swap? make sure you don't already have the correct parts such as distributor, 4 wire o2, and obd1 injectors (cut your resistor box off) or keep obd0 and keep the resistor box. i also assume you already have the ecu?
so what exactly is your question? what is the process of converting it all over? that should be in the directions that came with your harness? or did you go with someone elses/used harness that didn't come with directions. just trying to find out exactly what you need to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx »</TD></TR><TR><TD CLASS="quote"> 93 is obd o, so why are you converting?</TD></TR></TABLE>
90 91 =obd0
92 93 =obd1
right ?
90 91 =obd0
92 93 =obd1
right ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sit220 »</TD></TR><TR><TD CLASS="quote">
90 91 =obd0
92 93 =obd1
right ?</TD></TR></TABLE>
90 91 =obd0
92 93 =obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx »</TD></TR><TR><TD CLASS="quote">are you changing to obd 1 for ecu purposes or what? 93 is obd o, so why are you converting?</TD></TR></TABLE>
wrong answer..........92-95 is OBD1..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 »</TD></TR><TR><TD CLASS="quote">
wrong answer..........92-95 is OBD1..........</TD></TR></TABLE>
thats for civics he's talking about ls
bayron
13
Feb 26, 2009 08:04 PM
Fezzie
Aug 31, 2006 05:40 AM
