B20 turbo opinions
Hey wondering how many guys are out there with b20 turbos
I'm debating wheter or not I'm gonna boost mine. please state some setups , block builds, and psi + hp numbers
thanks
thanks
its ok i currently am goin to be running a b20 turbo setup. 7psi turbosmart wastegate with a precision sc62 turbo. i've searched far and wide about boosting these motors and ill i will say is dont goo too boost happy. the sleeves yes are thinner than other b series but it will hold on small amounts of boost. so far a freind of mine at the shop is runnin 8psi off his wastegate b20b turbo and is having only one problem and that is too much fuel up top in boost. other than that car runs great and strong cant wait to tune the motor :-)
I run a b20b turbo t3/t4 turbo .70 compresser .48 turbine homemade turbo manifold 440cc rc's, str fuel rail, drilled out aem fuel filter to -8an lines,walbro 255 in tank,areomotive FPR,crane cams coil and hi-6 box,turbo smart BOV and Wastegate,spearco front mount,ni crank pulley and hondata stage 3 completely stock motor
i run 8psi all day a i drive the **** out of my car all the time and the setup has been great have not tuned the hondata just called tom payn and had him send me a program for a b20 with 440's no dyno tune so far just cause im not done my down pipe but it feels realy strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siffredi »</TD></TR><TR><TD CLASS="quote">I run a b20b turbo t3/t4 turbo .70 compresser .48 turbine homemade turbo manifold 440cc rc's, str fuel rail, drilled out aem fuel filter to -8an lines,walbro 255 in tank,areomotive FPR,crane cams coil and hi-6 box,turbo smart BOV and Wastegate,spearco front mount,ni crank pulley and hondata stage 3 completely stock motor
i run 8psi all day a i drive the **** out of my car all the time and the setup has been great have not tuned the hondata just called tom payn and had him send me a program for a b20 with 440's no dyno tune so far just cause im not done my down pipe but it feels realy strong </TD></TR></TABLE>
did u ever run it w/o hondata b4?
