coolent leak---??
My car just started driping coolent on our first 90* day today. I was driving alot today, between driving, I noticed a liquid (seemed clear) that was dripping very slowly. What can I do about that?
I'll check, I'll edit when I get back to you. yes I did have A/C on, a lot actually, fricking hot here.
edit: it is dripping from the right front tire area. But father back then that. About 6 inches from where the tire touches the ground. It is clear liquid.
Thanks
Thanks
only thing i can think of right now that maybe almost clear and that far back is the tranny fluid there isn;t much else that would leak fro, that far back, there should be a bolt you can fit your socket in. It is Square shaped, make sure it is tight.. hope i could help you
I am going to jack up that area with the crappy jack the car came with and see if I can see where it is coming from. Then I can use pictures from my helms manual to see what bolt is leaking or what not.
vtec.dc2
Dec 8, 2015 02:53 AM
