distributor crack.. still good i think, please confirm
Old Jun 30, 2004 | 07:15 PM
B18EG6's Avatar
Default distributor crack.. still good i think, please confirm
hey... found this today. I dont think the crack will effect much, maybe a little oil dribble.
what do you think? This part does not rotate at all, just hold the o-ring there.
Old Jun 30, 2004 | 07:34 PM
N2O's Avatar
N2O
Default Re: distributor crack.. still good i think, please confirm (B18EG6)
Use it. You might want to start looking for a new one. It will drip some oil. Where did the missing piece go. I hope it is not in the head
Old Jun 30, 2004 | 07:38 PM
B18EG6's Avatar
Default Re: distributor crack.. still good i think, please confirm (N2O)
naw i have all the pieces, none are in the head at all
Old Jun 30, 2004 | 08:49 PM
redlineintegra's Avatar
I'd replace the o-ring and add some Hondabond to seal it up better as well.
Old Jun 30, 2004 | 09:19 PM
mmuller's Avatar
Mad Scientist
Default Re: distributor crack.. still good i think, please confirm (redlineintegra)
yep, as sayd just put a new o-ring.
Old Jul 1, 2004 | 04:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineintegra &raquo;</TD></TR><TR><TD CLASS="quote">I'd replace the o-ring and add some Hondabond to seal it up better as well.</TD></TR></TABLE>Try without HondaBond first, that stuff usually messes up the proper action of an O-ring. O-rings seal against the inner & outer surfaces. Look whether the bottom of the groove is smooth, & the inside of the hole (in the head) is smooth. The O-ring doesn't seal against the surface that's broken.
Use a NEW O-ring, like everyone says.
What happened? Use a crowbar to take off the distributor?
Old Jul 1, 2004 | 09:24 AM
B18EG6's Avatar
Default Re: distributor crack.. still good i think, please confirm (JimBlake)
naw i wasnt paying attention and put the dist on with the taper facing the wrong way. When I took it off that happened.
thanks for the advice
i think i know what you mean with the hondabond/o rings... i took off my oil pump and the o ring was almost eaten away by the hondabond! it was all brittle and mended itself to the hondabond
dark_samurai73
Oct 6, 2009 09:15 AM
bb4socal
Nov 12, 2007 11:46 AM
efking
Sep 28, 2006 12:44 PM
instructor74
Aug 24, 2006 12:58 PM
tegvtakkin
May 21, 2006 04:45 PM
