GT35R, 3.0 in dp, and AC setup...
finally took some pics of our T4 or GT35R AC compatible kit
basically with one of these, you can run a T4 or GT35R with a vband discharge to a full 3.0 dp and keep air conditioning. i wonder if i should put my ac back in
pics are of a GT35R housing....T4 is almost identical
Damn and I was going tuff it out and not go w/ ac and ps. I got that same turbo with t4 housing. Do you think it'll fit with the ATP turbine housing heat shield? How's clearance to the radiator? Still have to use civic half core or can I get a full size rad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Javier »</TD></TR><TR><TD CLASS="quote">thanks...its a tight fit, but real easy to put on with the vband
Definately!
<--- who is thinking of going EXCLUSIVELY v-band. I converted your guys t3/t67 to Vband Javier, after breaking off two bolts(my fault, used shitty bolts).
But yes, Vband is a lot easier to "cheat bend" w/out cheat bending. If that made any sense
</TD></TR></TABLE>Definately!
I dont understand why you guys dont make the manifold such that it hangs the turbo more towards the passenger side instead of having to rotate it towards the compressor. It seems more logical and theres always space in there to give the 3" downpipe more room to turn gradually.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">I dont understand why you guys dont make the manifold such that it hangs the turbo more towards the passenger side instead of having to rotate it towards the compressor. It seems more logical and theres always space in there to give the 3" downpipe more room to turn gradually.</TD></TR></TABLE>
Every manifold manufacturer runs into the same problem that can be summed up in three words:
"Clutch slave cylinder"
On the H motors, theres 5 words:
"Clutch slave cylinder, motor mount."
Pretty cool.
My only concern would be the oil return being so close to the d/p
Even braided stainless doesn't like heat like that....
Wish I could see the pictures.
